Fuel Pressure ?
Although not an expert, I will try to explain what I do understand.
The PCM adjusts the fuel flow to 14.x during closed loop operation, no matter the fuel pressure or the size of the injectors. It must be told the size of the injectors fairly accurately, and is adjusted with a tune.
During open loop operation, it uses the PE tables and the MAF table, which must also be adjusted with a tune. I have heard of cases where a slightly higher fuel pressure increased power without a tune.
In order to regulate pressure, you will need an adjustable fuel pressure regulator.
