Speedometer ?
Old Aug 15, 2007 | 05:47 PM
GreenBlood's Avatar
Default Speedometer ?
The search isn't working right now, but I was curious. Why do some firebirds, mostly the formulas, usually 93-94, have a speedometer that goes only to 110? I was looking at 0-60 and quarter mile times online(i know you can't trust these), why does the 94 formula seem to be the slowest of the LT1 birds? I that a myth, or are they really slower?
Old Aug 15, 2007 | 05:50 PM
Formula350's Avatar
The packages, just that simple. And related to tire rating a bit.
Old Aug 15, 2007 | 05:57 PM
GreenBlood's Avatar
So roughly how quick should a stock formula from 94 run the quarter? Is there a limit to the top speed besides tire rating?
Old Aug 15, 2007 | 07:00 PM
Zralou's Avatar
Cars that came without the 'Z' rated tires got a 115 mph speedo and a speed limiter of (if I remember right) 108 mph, which shuts off fuel to the car when it hits (I know, i've hit it MANY, MANY times!!).
Sara Lou
Old Aug 15, 2007 | 07:04 PM
GreatWhiteZ28's Avatar
Sara Lou
mine was 112, blasted thing got on my friggin nerves...not sure if there was any difference in the Birds and Z's or not or the 1 yr difference either...
Old Aug 15, 2007 | 07:18 PM
GreenBlood's Avatar
my 94 B4C had a 150 speedo, and the one time i was in a hurry, the last time i looked down, it was creeping towards 130, so I think the 94 formula's and zs differ in that sense?
Old Aug 15, 2007 | 07:23 PM
nope, B4C's didn't shut off, mine didn't have the Z rated tires from the factory, had a 150mph speedo, and shut off at 112
Old Aug 15, 2007 | 07:56 PM
fast's Avatar
both my '94 Z28s have the 155 speedo and 3.23 gears, no govenor
I was under the impression that the 110 speed was for 2.73 cars or possibly those with the 235/55 tires
Old Aug 15, 2007 | 08:01 PM
fast's Avatar
Sara Lou
Z tire rating is for 149 (or there about speeds)
look for code QLC (245/50) or QMT (235/55 standard size)
Old Aug 15, 2007 | 08:10 PM
you are correct sir
Old Aug 15, 2007 | 10:33 PM
ThoR294's Avatar
my 94 formula m6 had the 155 speedo. i did see a 94 t/a tho that had the 110 speedo. it looks dumb. i know all the v6s had the 110.
Old Aug 15, 2007 | 11:44 PM
GreenBlood's Avatar
is it possible to swap in a 155 speedo and reprogram the computer?
Old Aug 16, 2007 | 08:40 AM
GreenBlood's Avatar
bump for possibility
Old Aug 16, 2007 | 06:04 PM
GreenBlood's Avatar
evening crew
Old Aug 16, 2007 | 06:50 PM
fast's Avatar
not sure if it requires reprogramming (sure any tuner could do it if needed)
but swapping it is easily doable
Old Aug 16, 2007 | 11:28 PM
GreenBlood's Avatar
where could i find a nice set of gauges, how hard would the install be, i have never done anything like that before. I've only done exhaust, wires, plugs, etc. you know, small ****...
Old Aug 17, 2007 | 12:06 AM
the gauge swap on the birds are easy, my understanding is it's just plug and play swap...I just recently swaped to the newer style (98+) in my 95 Z and it was a PITA.....but was worth it in my eyes
Old Aug 17, 2007 | 12:07 AM
GreenBlood's Avatar
where can i get the parts for the bird swap? does anyone have a write up of an install?
Old Aug 17, 2007 | 12:42 AM
Red96TA's Avatar
my car sat on the needle a couple times......then the gas gauge switched needles...so i cut that out :-)
Old Aug 17, 2007 | 08:14 AM
GreenBlood's Avatar
bump...
