Big problem after o2 change
Old Aug 24, 2007 | 11:49 AM
lookin4aTA's Avatar
Originally Posted by racerns
I believe that the pass side O2 wiring and the knock sensor wire run down from the pcm together on that side of the engine. It is possible that you did someting to the knock sensor wire while you were trying to get the O2 out.
Are the wires Different colors? Hell I don't even know where the knock sensor is or what it looks like. That is what I am thinking happened. Hopefully all I did was knock something loose.
Old Aug 24, 2007 | 12:30 PM
jasonisdn's Avatar
passanger side right above the starter. to get the connector off (its a round type connector thats gray in color) just squeeze the sides of it and it will pull of very easy.
Old Aug 24, 2007 | 05:23 PM
96ws6ramair's Avatar
check to see if you burned up the wires that run down the engine bay right next to the hedders on the pass side this has happing to me right now also i have a bosh o2 that thing is the bigest peice of **** that is causeing my car to misfrie like cazy.
