Rcaetronix 32lbs flow specs in Tunercat
Im playing with my tunercat and i ve checked my basic tune for my injectors:
Racetronix 32lbs(Delphi 17208a)
Static Flow Rate @ 43.5PSI (300kPa) = 31.6 lb/hr = 332cc = 239g/m
Dynamic Flow Rate @ 43.5PSI (300kPa) = 6.68 gm/pulse - 2.5ms pulse width and 10ms repetition rate
In my Tunercat mail order tune(lt4) files i got:
Flow rate: 31.73 lbs/hr
Display flow rate: 3.81 Gl/Hr
Am i wrong if i think that i should have 31.6 of flow rate since those injectors are rated at the same psi of a f-body regulator?
And what about the display flow rate?
I would like to understand all this also,so with your answer a quick explanation would be appreciated
Thanks
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Thanks
