LT1 intake porting
Old Aug 22, 2007 | 12:52 AM
speed_demon24's Avatar
Originally Posted by TwoFast4Lv
Well...Start by cutting the top off...see top of pic
Then look inside
My intake was highly modified and I am about $600 in welding alone. My Guy is good and I can not weld aluminium. there is anouther $500-600 in porting and flow work on and off a flow bench. Plenum volume is about 2/3s more then stock.
the top plate was made that way for porting and flowing purposes only. It is Bolts and siliconed back on.
The attatched pics are from the LT4 intake we did
For the price of all that why didn't you just go with a sheet-metal intake?
Old Aug 22, 2007 | 02:03 AM
TwoFast4Lv's Avatar
I don't know. I started with this
AND i Had this at the time..The line up is LT1, Hogans, LT4
Hogans Vs LT4
Old Aug 22, 2007 | 11:46 AM
Vicious95Z28's Avatar
I want a Hogans, I don't really need it yet but I want it anyway!
Old Aug 22, 2007 | 12:02 PM
ZONES89RS's Avatar
In-Zane Moderator
WOW, that is allot of hacking, that is what needs to be done for serious power though.
Old Aug 22, 2007 | 12:49 PM
Irocss85's Avatar
so did you also extend the runners up higher into the new upperpart of the mannifold? awesome pics so far. might make me reconsider goin supervic/carb.
Old Aug 22, 2007 | 03:54 PM
That sheet-metal looks nice as hell, did you ever put it on and see what kind of gains it had over a ported lt1/lt4 intake?
Old Aug 22, 2007 | 08:55 PM
TwoFast4Lv's Avatar
The way the Plenum inlet is made it would be hard to extend the runners with out disrupting the flow. So no runners are same length.
We did fin the higher we made the plenum the better it flowed. It flowed best with the top off.
We tried all kinds of ideas on the intakes. they seem to be working but we have yet to do a stock to modified intake dyno. Just not quite as easy as a LSx
Old Aug 23, 2007 | 12:39 AM
ZONES89RS's Avatar
In-Zane Moderator
Come on, they are not that bad ither....DO IT, nike that **** so you can see on paper what kind of difference you are making.
