Pacesetter LT people, come in here!
Old Aug 19, 2007 | 12:18 PM
Ironxcross's Avatar
Default Pacesetter LT people, come in here!
How did you seal the slip fit collectors? I cant seem to get them to seal and I think its killing my mileage.
Old Aug 19, 2007 | 12:21 PM
GreatWhiteZ28's Avatar
I switched the clamps over to the sleeve/band style clamps
Old Aug 19, 2007 | 03:56 PM
blk97z28's Avatar
Yep!! Band clamps, i have also seen a brass band clamp.
Old Aug 19, 2007 | 04:01 PM
Irish350's Avatar
and black silicone
Old Aug 19, 2007 | 04:04 PM
Revelation Z28's Avatar
im currently using the U bolts they gave me and im starting to feel some exhaust pulse coming through. im gonna switch over to napa's 3" stainless bandclamps.
Old Aug 19, 2007 | 04:06 PM
Irish350's Avatar
oh yeah, definitely go stainless... when i bought my borla the clamps (and flanges) were all rusted out.. very not pretty..
Old Aug 19, 2007 | 04:11 PM
James Montigny's Avatar
Welded those suckers shut, I got tired of the leaks.
Old Aug 19, 2007 | 04:38 PM
blk97z28's Avatar
NO I would never weld my headers to my y-pipe
Old Aug 19, 2007 | 04:43 PM
Puck's Avatar
I did too. It's not exactly the right way of doing things, but I suspected a leak there and wanted to be sure.
If in the rare case I must drop my exhaust(havent had to yet), I can just cut it down and re weld it when I'm done
Old Aug 19, 2007 | 04:58 PM
Ralls's Avatar
Stainless steel band clamps. It still leaks some, but it will seal if I put a bead of RTV around it.
Old Aug 19, 2007 | 06:02 PM
donkey mule's Avatar
Stainless steel uclamps for me. No leaks.
Old Aug 19, 2007 | 06:09 PM
kinglt-1's Avatar
did any body notice how they are welded inside the primary? That makes the ports like 1 1/2 inches stepped into a 1 3/4 primary. Seems like a big restriction to me. My current bbk 1 5/8 shorty's are welded on the outside, makes me wonder if its even gonna make a difference putting the pacesetter lt's on.
Old Aug 19, 2007 | 06:19 PM
Ralls's Avatar
There's more to it than you think. The stepping design inside the header makes a low pressure zone and helps out with back pressure. And yes, you want back pressure.
Old Aug 19, 2007 | 07:01 PM
Irish350's Avatar
why not just switch to 3 bolt flanges (all you guys with leaks)?
Old Aug 19, 2007 | 10:10 PM
kinglt-1's Avatar
I figured it prolly had to do with back pressure, just wasnt sure if these would be good for my 383.
Old Aug 19, 2007 | 10:42 PM
socal's Avatar
3 bolts blow out to much and come loose i like the band clamps and the v-band kind
http://www.jegs.com/webapp/wcs/store...63129_-1_11527
http://www.jegs.com/webapp/wcs/store...11527_-1_10245
Old Aug 19, 2007 | 10:44 PM
hyperzone's Avatar
Leaks??? bwahaahaa! I have the band clamps that came with the TSP x-pipe rumbler setup. Not leaks... Actually when I went to pull the headers apart from the rest of the exhaust for the first time in 2 years, I had to go apeshit on them. Wouldn't budge at first they were wedged/sealed so good. Sheeeeit, I'd be scared to put any extra adhesives or crap in there after all the pulling and twisting it took to get'em off. I sorta like the 3 bolt flange idea.
edit : my band clamps are about 4 inches wide and have a stepped ridge where the exhaust overlaps the header. And there's two bolts that do the clamping.. have to get a better picture sometime. And when I tighten them up, I use the impact gun.
Old Aug 19, 2007 | 11:45 PM
Ralls's Avatar
Sounds like the ones I have. http://store.summitracing.com/partde...5&autoview=sku
Old Aug 23, 2007 | 06:04 PM
96mikez28's Avatar
I have those too, and like them
Old Aug 23, 2007 | 08:51 PM
Puck's Avatar
Arguable.
...but thats a whole 'nother thread
