canton
Old Aug 19, 2007 | 06:28 PM
darrell hoagland's Avatar
Default canton
just finished putting my motor together.i have the canton oil pan on it when i turn my motor over it sounds like the crank is rubing the pan
Old Aug 19, 2007 | 07:12 PM
Irish350's Avatar
uh oh.. did you get like a low profile pan and a big diameter crank?
Old Aug 19, 2007 | 07:56 PM
socal's Avatar
I'm building my 396 and was thinking of using a canton pan which one did you get (part number) so i don't get that one. Is it a stroker or stock size crank? I hope your turning it over by hand.
Old Aug 19, 2007 | 08:19 PM
jasonisdn's Avatar
you are hitting the scraper. pull it off ,look for the marks. 2 chioces 1. grind on it with a dremel or something else. then take it apart and WASH it out. 2. take a hammer to it and bend the scrapper down. then take it apart and WASH it out. i had the same issue with my canton. then you will be fine
Old Aug 19, 2007 | 08:43 PM
sheikss's Avatar
Wow had the same problem on my canton with a 383. I bought it because it was suppose to clear a stroker. I took the hammer to it.
Old Aug 19, 2007 | 09:05 PM
jasonisdn's Avatar
yeah its common. for the record it was the road racing pan for the lt1 f-body 15-242t
Imnotfast's Avatar
The gasket also hits the crank. Its near the oil filter area. Sounds like it hits the pan but really the gasket.
