What's up
Old Aug 21, 2007 | 03:09 PM
nomoneyz's Avatar
Work and school. Trying to find time to install a new tranny.
Old Aug 21, 2007 | 03:53 PM
chavez885's Avatar
Saving up for a clutch and some giggle juice...mmmm
chavez885's Avatar
How's the car running merv?
Old Aug 21, 2007 | 05:45 PM
jakesz28's Avatar
Work and trying to figure out what I should put a motor in first. My beater 91 truck or the camaro? Ah my '02 sunfire has a rod knocking too. It's been a bad year at my place.
Old Aug 21, 2007 | 06:49 PM
the_merv's Avatar
Veteran: Air Force
Damn man, sorry to hear..
It's runnin real strong Chavez..just working out some bugs here and there..
Old Aug 21, 2007 | 08:32 PM
94Pontiac's Avatar
made it to the track last weekend....
Old Aug 21, 2007 | 08:42 PM
little Red Camaro's Avatar
Merv check your PM...need to ask you some questions about swapping out my LT with LS motor..have donnor car and have some questions!
Old Aug 21, 2007 | 10:39 PM
the_merv's Avatar
Veteran: Air Force
It helps when you answer your phone..
Old Aug 21, 2007 | 10:43 PM
socal's Avatar
Originally Posted by the_merv
Could be the PVM(it's close to that) Solenoid..
do you mean pwm (pulse with modulate)
Old Aug 21, 2007 | 10:56 PM
the_merv's Avatar
Veteran: Air Force
^^that's it.
Old Aug 21, 2007 | 11:35 PM
SLawson86's Avatar
pulse width modulation is PWM. there are a number of things that can cause it to not go into lock-up... but i would start with the solenoid, they tend to **** out quite a bit. take the pan down, and you cant miss it!
Old Aug 21, 2007 | 11:37 PM
  #32
SLawson86's Avatar
i dont know your actual technical ability nor your tool array, but i personally would put an oscilloscope on the solenoid, or get a DMM that measures duty cycle... the best way would be with a tech II though... command for lock-up and see the slippage. also check for your brake on-off switch (brake switch under the pedal) if i can help anymore, pm me. MERV sorry for jacking your thread
Old Aug 21, 2007 | 11:53 PM
  #33
ZEX-Z's Avatar
My tranny will be back tommorrow and my 396 LT1 with the LE3/4 head and cam kit is complete. I will be posting the installation pics as soon as we drop it in. She's coming for ya.......
Old Aug 22, 2007 | 01:32 AM
  #34
the_merv's Avatar
Veteran: Air Force
It's all good..we were collectively talking about it..
That's a nice Engine, I like them Headers..
Old Aug 22, 2007 | 01:44 AM
  #35
1bdbrd's Avatar
Trying to convince myself to not sell my non-running POS for this local nice and cheap 95 5.0L 5 spd Mustang GT. I am at whits end with this damn car and can't figure out whats wrong with it.
Old Aug 22, 2007 | 03:17 AM
  #36
the_merv's Avatar
Veteran: Air Force
What's it doin..you have a thread..
Old Aug 22, 2007 | 05:09 AM
  #37
camar0corey's Avatar
working outside 9+ hours a day, so not doing much. My truck has been on jackstands for almost a month now, its too damn hot to be working on stuff outside. Well I was making progress on the truck, lower ball joint is either the wrong part or my lca got damaged.
Got a Corbeau Forza seat sitting in my room, have a Sparco harness on the way. Just have to get motivated to paint my roll bar and I can get to work on the interior.
Did the LED swap for my gauge cluster, destroyed my dash pad......
Got tailgated by a cop last weekend at 11:45 PM, what I can't cruise my Camaro or something?
