i found this odd
Old Aug 20, 2007 | 09:55 PM
Chris18927's Avatar
Default i found this odd
I had heard this from a friend but then i was talking to this guy at best buy and he said that his gas mileage doubled in his car. He said that if you get a shorter serpentine belt to bypass the a/c compressor it puts less stress on the engine and you get a lot better gas mileage. even if you just drive with your a/c off and you bypass it you get better gas mileage. does this work, any1 tried it?
Old Aug 20, 2007 | 09:59 PM
tonskiguy's Avatar
I think you'll need the delete pulley. If you remove compressor, condensor, plumbing, etc... youl'll save 15 - 20 lbs. You won't double your gas milage. I doubt if you'll notice any difference compared to not running it.
Old Aug 20, 2007 | 10:02 PM
speed_demon24's Avatar
It's bs
Old Aug 21, 2007 | 12:33 AM
ZONES89RS's Avatar
In-Zane Moderator
Bulllllsheooot!
Old Aug 21, 2007 | 01:07 AM
Fbodynightmare's Avatar
Default A/c?
Unless your talking about a race car why the heck would you want to bypas the a/c ?? I dont care what weight you'd loose not worth it.
Old Aug 21, 2007 | 08:41 AM
LT1Falcon's Avatar
buddy even if you took the serpintine belt all the way off, it wouldnt double your mpg. that would mean that half of the power your engine is making is used to turn your ac and the other have is used to pull you down the road and friction.
use your head
Old Aug 21, 2007 | 09:12 AM
B4CZR2's Avatar
LT1Falcon That car is awesome!!
Old Aug 21, 2007 | 09:58 AM
LT1Falcon's Avatar
thanks man i appreciate it
Old Aug 21, 2007 | 12:10 PM
Captainofiron's Avatar
driving with your A/C turned off is the same as deleting the A/C,
drive like that for a week and see how it does, it might go up a 1 mpg or 2, but I doubt it
Old Aug 21, 2007 | 08:17 PM
Chris18927's Avatar
thats what i thought but the guy at best buy told me that that was the way to go
Old Aug 21, 2007 | 08:33 PM
donkey mule's Avatar
Did the guy at best buy also suggest the turbonator?
Old Aug 21, 2007 | 09:03 PM
Formula350's Avatar
The ONLY reason it would double, is if his clutch was bad and stuck in the ON position. Essentially he'd be driving around all day with his AC on, and bypassing it WOULD help then.
Old Aug 21, 2007 | 10:00 PM
Bones Z28's Avatar
yeah thats bullshit obviously.
Old Aug 21, 2007 | 10:03 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Question
Got any pics of the FALCON...Looks COOL.
Old Aug 22, 2007 | 06:06 AM
LT1Falcon's Avatar
i got a few more on my computer i will see if i can get them
