Shaking
Old Aug 23, 2007 | 08:38 AM
the_merv's Avatar
Veteran: Air Force
That's decent.
How many miles on it?
Old Aug 23, 2007 | 10:58 AM
GreenBlood's Avatar
car was souped up by first owner until 90k miles, second owner put it back to stock and replaced almost everything with new stock parts, minus the block...car currently has 133,855 miles...i've put over 200 miles on it since i got it on sunday, I can't stop driving it, lol...f-bodies are addicting...
Old Aug 23, 2007 | 10:59 AM
GreenBlood's Avatar
i lucked out though, one of my friends that just bought a C5 has a friend with an LS1 T/A, and the guy with the T/A has a GM scanner, so I am gonna try and hit him up to see if my car needs anything...
Old Aug 23, 2007 | 01:17 PM
Ralls's Avatar
If it's a Tech 1. Tech 2's are for OBD2
Old Aug 27, 2007 | 10:12 AM
moserman's Avatar
check the wire jacket on the O2 sensors and the jacket on your plug wires. they might be shorted out, just an idea...... i had the same problem and replaced 1 plug wire and replaced the wiring on the O2 sensor, and it ran like a champ afterwards.
Old Aug 27, 2007 | 10:18 AM
3pnt4maro's Avatar
as for the coolant light..just check it and if its fine the sensor has malfunctioned..just keep an eye on your temperature..if its good then your fine...Mine went out a couple of weeks ago..check your coolant level every couple of weeks and you will be good...the pressure sounds about right...
