Turn signal ?
Old Aug 23, 2007 | 06:51 PM
GreenBlood's Avatar
Default Turn signal ?
My right one works, left one turns on but doesn't flash like the normal turn signals...search isn't workin for me...
Old Aug 23, 2007 | 07:43 PM
GreenBlood's Avatar
anyone? is this an easy fix i can do myself?
Old Aug 23, 2007 | 07:52 PM
redneck01's Avatar
check your bulbs in the front and rear. if it is staying on and not flashing..its a bulb OR the wiring to the bulb is bad. had bad wires after a 100k miles and if they shook loose they'd stop flashing. check bulbs first
Old Aug 23, 2007 | 08:02 PM
GreenBlood's Avatar
ok, is it hard to change the bulbs on these? where could i pick up the wiring if thats the problem? I am bringing in the car tomorrow to get the A/C checked because it seems to be royally fucked...I might as well have them take a look at that too...
Old Aug 23, 2007 | 08:04 PM
koolaid_kid's Avatar
A flasher works on current draw. The more draw, the faster they flash. And if the current draw is too low, it won't flash at all, it will just come on and stay on.
So I agree, the easy check is the bulbs. The contacts for the bulb could also have become corroded over time, not allowing enough current to flow to the bulb.
Old Aug 23, 2007 | 08:07 PM
To change/check the rears, you just need to pull the cover off the back of the trunk. IIRC, the fronts change out from underneath. Both are pretty easy to do, just takes a little patience.
When I did my rears, I changed them all at the same time. They were all the same age, after all, and would have failed soon anyway. And clean the contacts when you do it, they will have at least a little corrosion on them.
Old Aug 23, 2007 | 08:42 PM
GreenBlood's Avatar
what'd u clean the contacts with? like wd-40?
Old Aug 23, 2007 | 08:44 PM
ZONES89RS's Avatar
In-Zane Moderator
They sell electrode grease, i use it when i have it, cleant it with a brush and maybe brake clean if it is all nasty and crusty.
Old Aug 23, 2007 | 08:47 PM
GreenBlood's Avatar
can i get that **** at autozone?
donkey mule's Avatar
Good advise!
Old Aug 25, 2007 | 09:18 AM
redneck01's Avatar
yea i just gave up on mine..both stopped working when i rewired stuff..and i just never needed them anymore because it just races
Old Aug 25, 2007 | 10:44 PM
Formula350's Avatar
My left works and right does when it wants to. The bulb is very dim though. I suspect a ground issue inside the plug, but haven't taken the time to clean inside. It's not grimy or anything. I replaced all my bulbs too, so that's not it :\ Some days it work's fine, some days it works very slow, some days it just doesn't work. Very annoying.
Old Aug 26, 2007 | 01:47 AM
GreenBlood's Avatar
i had my mechanic check it, he said it was the ground...He fixed it for free, but it only worked for about 3 hours, and now it does the same **** again...The right one works beautifully though, lol...
Old Aug 26, 2007 | 01:51 AM
LT1 Guy's Avatar
Try replacing the flasher unit.
Old Aug 26, 2007 | 02:29 AM
ZONES89RS's Avatar
In-Zane Moderator
Dude, that is fakked, i would be pissed, better you than me
