I need some help
Old May 26, 2003 | 11:41 PM
mike97ss's Avatar
Default I need some help
On the way home from a friends house my car misses realy bad for a second then its fine. 15 seconds later it does it again for a little longer then goes away. Well the third time it dose it and dies. My friend had to trailer me home. Now the car wants to turn over but cant, it seems like it gets an initial spark and thats it. I just put an msd coil and 6A box with new wires and plugs. I know its getting fuel. You think it might be an opti or the MSD box ?
Old May 27, 2003 | 07:56 AM
Tin Indian's Avatar
Default Re: I need some help
I'm not a big LT1 expert, but my son's 95 TA did the same thing. This was a car with a Procharger and an MSD BTM ignition box. Sometimes it would start, sometimes not. Fuel pressure was good. Appeared to have spark. Replaced the PCM (waiste of $$$), but that did not fix the problem. Turned out to be the infamous "Opti-Crap". And it wasn't cheap, to say the least.
Come to find out that even though it had spark, the ignition timing during start would get so far off at times, it just could not start. Very strange that it would have spark, but, at times change the timing so dramatically.
Good luck,
Ron
Old May 27, 2003 | 11:10 AM
ChrisB's Avatar
Bypass the MSD since that is free - but if that doesn't work it is probably the opti-spark.
Old May 28, 2003 | 12:01 PM
ghostle's Avatar
I`ve heard of people upgrading to msd or other brands and destroying opti`s. Not everytime but sometimes.
Old May 29, 2003 | 10:15 AM
The Big Show's Avatar
Ditto what Chris B said. I've seen opti's die right on the spot so the myth of them progressively dying doesn't necessarily hold true for everyone.
Old May 29, 2003 | 04:31 PM
96SCTA's Avatar
The brand new one i installed 2 months ago. Lasted only 16 miles. The symptoms where it got harder and harder to start each time. Finaly it just went. These things seem to either go in a hurry or work just fine. That is the experiance i have had with them.
