Maf sensor
Old Aug 28, 2007 | 05:47 PM
GreenBlood's Avatar
Default Maf sensor
The owner before me replaced this before he stopped driving the car and I bought it. However, since the new one, the car runs fine, but the SES light is on...It turns off at idle, but once you start to accelerate, the light comes on and stays on until you come to a complete stop...The previous owner said the computer needed to be reprogrammed or something for the new sensor?
Old Aug 28, 2007 | 06:50 PM
GreenBlood's Avatar
bump...
Old Aug 28, 2007 | 07:45 PM
GreenBlood's Avatar
anyone?
Old Aug 28, 2007 | 08:38 PM
infinitebird's Avatar
If the MAF sensor is an aftermarket one, you might need to have it reprogrammed, however such programs are notoriously difficult to do. If it's another stock sensor, you shouldn't need any programming.
Have your car scanned to see what the code is.
Old Aug 28, 2007 | 10:01 PM
GreenBlood's Avatar
i think the maf sensor is aftermarket
Old Aug 29, 2007 | 12:26 AM
GreenBlood's Avatar
anyone else?
Old Aug 29, 2007 | 02:36 AM
Ralls's Avatar
Aftermarket MAF's are always trouble in my experience. They make things worse.
No use in guessing what the SES light is about.. get it scanned and find out.
Old Aug 29, 2007 | 03:36 AM
koolaid_kid's Avatar
Unfortunately, I agree. Please pass along the code, and we can try to help. Any MAF, aftermarket or not, should tell the PCM that all is well. I ran a Granatelli for a while, and it never set a code.
Have you tried cleaning the MAF with an electronics spray cleaner?
Old Aug 29, 2007 | 11:19 AM
GreenBlood's Avatar
not yet...I am going to be out for today, but when I go and get my A/C fixed, I might as well have him scan the code...My car will probably me down for a few weeks, maybe less because I am bringing it in do get the dent on my driver side rear quarter fixed, and I am gonna get the paint touched up because there are some chips on the spoiler and hood. Also, that molding piece that runs down the center of the door on firebird's is fading, so I am gonna get those repainted...Car should look sexy after that....
Old Aug 29, 2007 | 12:21 PM
ZONES89RS's Avatar
In-Zane Moderator
I cleaned mine with carb cleaner, worked great, just make sure you dont touch the inside of the sensor.
Old Aug 29, 2007 | 12:49 PM
Ralls's Avatar
I wouldn't paint the molding. Just take it off. Have you seen what it looks like off? It's much better if you ask me.
Old Aug 29, 2007 | 02:44 PM
Several cleaners should work, including brake cleaner. I tend to the conservative, and now use electronics cleaner. It should say "leaves no residue" or similar, on the can.
Old Aug 29, 2007 | 02:55 PM
Ralls's Avatar
I found out electric cleaner is the best solution for the MAF. If the hotwire is dirty, you can use a que tip.
Old Aug 30, 2007 | 12:04 PM
GreenBlood's Avatar
is the molding easy to take off? I am also thinking about removing the formula badges as well....
Old Aug 30, 2007 | 12:57 PM
Ralls's Avatar
Yeh it's simple. Slowly peel it up and try to get as much of the glue to come off with it. The glue is the most annoying part if it stays on. Search the appearance section for more info.
Old Aug 30, 2007 | 01:01 PM
GreenBlood's Avatar
sweet, thanks man...
