"Stepped" headers?
The only problem I have is with the #5 primary. It is tough to get to the spark plug. Besides that.....they rock! Remember you will need a manual p/s rack and delete or modify the evap box for these headers.
Originally Posted by roadtrip120
Kooks are supposed to work with factory parts, but only time will tell. Mine are still not in the car.
Undercar clearance is fine.
With my small arms plugs are easy as well.
And you can keep PS if you get a flaming river U-joint for the steering linkage The heater box does need some serious modification though.
Tony.
Tony.
I run the stepped Kooks with the emissions fittings and a stock pan...The only mod was switching to an AC PF454 filter and very slight clearancing of a steering coupler bolt head...Under car clearance is fantastic and plug access is good...They are works of art and look great as they age..They get kind of a golden color to them...
--Alan
--Alan
#32
Originally Posted by TwoFast4Lv
What is this "Heater Box" you speak of
Your A/C box that sticks through the firewall, right next to the heater core lines, on the passenger side of the car.
#33
Hmmm... I will have to look harder I can't seem to find it
