is it safe to drive my car???
Old Aug 30, 2007 | 09:22 AM
94_lt1_4mula's Avatar
Default is it safe to drive my car???
i just installed a gm847 cam and im wondering because im changing my fuel injectors to 30# SVO injectors, would i be able to drive without damaging my engine because i will be running TOO rich...or should i wait till i get a tune
thanx
Old Aug 30, 2007 | 09:27 AM
engineermike's Avatar
Put the 24's back in it and drive it around. It doesn't take long to swap them. They'll support 350+ rwhp anyway. . .
Old Aug 30, 2007 | 10:20 AM
ZONES89RS's Avatar
In-Zane Moderator
I think it should be fine, just make sure you need a injector that size, you can wash out rings in the cylender, but it usually is a poorly tuned carb or a huge injector running rich due to bad O2s.
Old Aug 30, 2007 | 11:59 AM
GreenBlood's Avatar
sorry to thread highjack, but where did you buy the blackout tailights? i am having trouble finding them...
Old Aug 30, 2007 | 12:09 PM
Bersaglieri's Avatar
Use your stockers till you get a tune. Why risk it when they shouldnt have a problem?
-Dustin-
Old Aug 30, 2007 | 12:42 PM
daniel6718's Avatar
USE YOUR STOCKERS UNTIL YOU GET A TUNE...otherwise the rings are goana get worn down and your car will smoke until you remove it and rebuild it...
theres no need for 30's for a cam only car anyways...you should be fine until after 375 hp
Old Aug 30, 2007 | 12:48 PM
ThoR294's Avatar
they are not blacked out tail lights, they are just plastic covers that simply snap on over the stock tail light.
Old Aug 30, 2007 | 01:00 PM
GreenBlood's Avatar
i know, thats what i meant, I can't find those covers anywhere...I had them on my camaro, and those are abundant, but I can't find the firebird ones...
Old Aug 30, 2007 | 01:41 PM
Dragframe's Avatar
if you get a tune with the new injectors you will be good.
Old Aug 30, 2007 | 05:14 PM
ThoR294's Avatar
http://www.autopartswarehouse.com/pr...ory=tail_light
Old Aug 30, 2007 | 05:27 PM
actually they are...somewhat...because i sprayed it with lens tint spray...@ $25 a can...and my tails are without a clearcoat...
and thanks for the info i'll wait till i get a tune...even though i'm running a wet shot i thought i would go w/ the 30's...so for future mod's i wouldn't have to change them
