opti opotions
Old Aug 30, 2007 | 03:13 PM
carreras's Avatar
Default opti opotions
a buddys opti went out today and he was wondering what his options were as far as replacing it? He has a lt4 hot cam and most of the bolt ons. He still has warranty on the one that he bought from o'reilys, but dosent want to replace it with another cheap one. any info will help thanks.
Old Aug 30, 2007 | 03:19 PM
Bones Z28's Avatar
MSD or Delteq. Those are both top of the line. Personally i went MSD and i'm very very satisfied with the results.
Old Aug 30, 2007 | 05:18 PM
carreras's Avatar
where can i find the delteq and is there a huge price dfferance between the two?
Old Aug 30, 2007 | 06:45 PM
Z28_DAD's Avatar
just warranty the one from orielys and get this http://www.bailey-eng.com/
with out the high voltage going through it, it will last alot longer
Old Aug 30, 2007 | 08:49 PM
dhdenney's Avatar
The Delteq and LTCC still require the optical/lo res portion of the opti as a cam position sensor. If you got the opti and O'Reilly's it's still probably not any good.
Old Aug 30, 2007 | 09:39 PM
jasonisdn's Avatar
i am going to **** on my msd when i pull it off. going back to a factory opti. when a company, that builds 8 sec cars and other crazy setups, tells you the msd sucks before a dyno event. then during the dyno you have major spark issues. well after you changed the plugs, checked the wires, changed the coil and the ICM and the graph still looks like a bad 80's hair cut. i do belive you would hate a msd opti also, much like myself. i would be willing to try the delteq. also screw a dynaspark, if they don't want to make them for people to buy let them sell the design to someone who will fill the orders.
Old Aug 31, 2007 | 10:09 AM
carreras's Avatar
what company sells delteq? or where can i find one? so his options are to warranty the one he got from o'reilys and get the delteq or ltcc. Or he could just buy the msd. I really havent heard to much bad things about the msd. still a hard choice.
Old Aug 31, 2007 | 11:12 AM
dhdenney's Avatar
www.delteq.com/ I wouldn't warranty the one from O'Reilly's as it might not provide an adequate lo res pulse.
Old Aug 31, 2007 | 02:17 PM
Captainofiron's Avatar
get the MSD
the only people who have problems with it, either installed it wrong, or had problems with the o-ring.
Old Aug 31, 2007 | 02:23 PM
syclnjr's Avatar
I personally would go with LTCC that bailey-eng.com sells. yes you pay 400 bucks for the harness and the box, you have to buy the ls-1 coils and wires, but have heard nothing but great things with there customer service and the way the system works. All Deltec conversion does is essentially put cadillac style coils on it. Same concept as LTCC but IMHO LTCC is the way to go since they are easy to mount, the LTCC box has built in timing retard for boost, nos what ever. Rev limiter too. If I end up doing the conversion it will be that. my 2 cents
Old Aug 31, 2007 | 02:40 PM
jasonisdn's Avatar
Originally Posted by Captainofiron
get the MSD
i don't belive that. when a shop that builds cars for a living (ls1 and lt1's) , tells you the msd sucks belive them. they have installed and removed msd's due to issues. i can see getting a bad batch but this is crazy. i had the new square type gasket and i am very carefull with everything i do. i made sure i had clearance and that i used red threadlocker on the button bolts. i will take photos when i pull it off within a few hours. i will never buy another msd product. read this, atleast msd is trying to work on the issues.
http://web.camaross.com/forums/showthread.php?t=539869
Old Aug 31, 2007 | 03:21 PM
infinitebird's Avatar
You should ditch the one from oreilly's and either get a new GM or MSD opti to replace it. If you want to do the delteq/ltcc then you can after that but you still need a good working opti to use either, which oreilly's are not.
Old Aug 31, 2007 | 04:34 PM
jasonisdn's Avatar
now i am not saying the dragging is a issue , it just shows quality issues. my car was running lean , popping back firing and missing all the way up the rpm band from idle. we changed everything on the car that would effect it and checked the rest. the opti is the only other source. when i finish my install (of factory opti ) shortly i'll post the results. 7 meg sony camera and it can't take a better picture than that , up close bah
Old Aug 31, 2007 | 07:20 PM
jasonisdn's Avatar
well guess what. car is as smooth as silk. pulls hard and good , no sputtering and no crappy idle. now i am ready to go to the dyno on thursday wwwweeeee
Old Aug 31, 2007 | 07:28 PM
96lt1m6's Avatar
gm opti?
Old Aug 31, 2007 | 08:04 PM
dhdenney's Avatar
Rotor button looks like MSD.
Old Aug 31, 2007 | 08:40 PM
96lt1m6's Avatar
oh yup,blind in one eye and can't see with the other today.
Old Aug 31, 2007 | 08:51 PM
jasonisdn's Avatar
Originally Posted by 96lt1m6
gm opti?
sorry for the confusion, the pics are of the busted MSD (POS). the car is running great with a fatory gm opti , gm coil and of course ICM. i would give the specs of the motor but a sponser of CZ8 will be doing that after we dyno tune it thursday.
Old Sep 1, 2007 | 01:29 AM
ZONES89RS's Avatar
In-Zane Moderator
Hell, i cannot wait to get mine from the dude off ebay, i pray it is quality...PLEASE PRAY FOR ME!!! Seriously, i need all the help i can get.
Old Sep 1, 2007 | 05:32 AM
jasonisdn's Avatar
my heart goes out to ya. another company is working on a setup like the ltcc. hopefully i can talk him into letting me run 1 of the first versions.
