Kooks LT/Y-pipe vs. Pacesetter LT/Y-Pipe.
Originally Posted by ThoR294
but with pacesetter, they do not have cats in the y-pipe, ill bomb emissions no?
Originally Posted by 1bdbrd
That must explain why people have to clearance things to get the overpriced and over rated Kooks to fit. My pacesetters fit just fine and the y pipe fits even better.
Mine fit perfect!!!!!!!!! You cant beat the quality of Kooks
i just passed inspection, but i know they only look for a cat on the bottom of my car im pretty sure... then they plug it in to the computer and check the readiness monitors...
so, just LTs and an ORY pipe, and only the after cat... haha
Originally Posted by speed_demon24
You get what you pay for.
ah ok. So I guess pacesetter would be for me. Im goin for a mild/mod street car
haha. My concern is will my SES light come on if i put them on. I guess i need a y-pipe with cats?
Originally Posted by Fastbird93
Here's what you can do and what the issues are. First, moving a cat from the stock location is an automatic failure if the tech knows what they're doing and wants to be a turd. If a visual inspection is done with a catless Y-Pipe, nine times out of ten you'll get failed too. If you go the catless route, make sure you get a tune and have the rear O2's deleted. Thus, no SES light. If you get a catted Y-Pipe, you shouldn't have a problem with the SES light coming on. If you do, delete the rear O2's via tune, and no more SES light.
I want to go with cats in the Y-pipe. does pacesetter make a y-pipe with cats in it and the o2 holes? I forget, are the o2s in the headers and then the post-cat one after the y-pipe meets?
Well i've been told at mfba (my local club) that the pacesetters are good for 400-450hp. The hookers and kooks are "tuned" headers so you want to look into something like that if your going all out. If it's a straight race car then yeah get the kooks or hooker super comps. Idk man i'm in love with my setup. I went with the ceramic coated pacesetters. Those through the borla sound friggin awesome, i'm very very pleased. I know several people through my club that run them on 450hp plus cars with no problem. So performance isn't really an issue. But if that thing is going to be a straight racer then i would look into hookers or kooks. Your call, but again i think best bang for your buck would be the coated pacesetters.
Yeah if you have a visual inspection man take apart a cat cut it in half and just weld the casing around the y pipe. Who the **** would no the difference. They'll look underneath and see a cat there. Chicago doesn't have anything like that. Just plug and in the obd2 port. So i got the race readies and a pcm tune. But if they ever got stupid that's exactly what i'd do. Weld a crappy old cat to the y pipe. Emissions qaulified
If you have a visual inspection there like I think you do, no matter what you do you WILL fail with long tubes. They move the original location of the cats so even if you put some back on, they still wont be legal. You might be able to get away with it, but know that even with emission fittings on the headers AND cats in the y-pipe, that you are not emissions legal.
Originally Posted by -PEPE-
hijacking your thread here Thor but that is one clean TA.
its clean. I like your stroker :O Im planning on building a 94 lt1 motor i have into a 383 stroker that I can eventually put into mine far down the road
the strut towers sparkle
