New Best!
Yours is still my favorite ever.
Im guessin this was in the TA?
Get back out there and lets see some 8s
Which one was it? only one I can think of with a T/A is the "gimme 20 lengths" Civic cry baby dude.
> 4-bolt main LT4 block
> Lunati 4340 forged racer crankshaft
> JE Custom Pistons 9to1 compression HellFire rings
> Lunati 5.85" Pro Mod Rods
> Morel Lifters
> BIG CAM!
> ARP Block stud kit - 4-bolt mains
> ARP Head stud kit
> Canton Oil Pan and Pickup
> O-Ring block - Receiver groove
> Melling M55A Oil Pump
> Comp Cams double-roller timing chain
> Custom Push Rods
> SCE Copper LT1 head gaskets
> Advanced Induction 210 TFS LT1 heads - 64cc chamber - O-rings
> Stock AI ported LT1 intake
> BBK 1000 CFM 58mm throttle body
> Kooks stepped race headers 3-1/2 collectors
> ATI D1 Maxed out 20+PSI
> Mezeire HD Electric Water Pump
> Custom Blower Intake
> Custom Fuel System:
> Aeromotive Eliminator fuel pump
> Paxton Boost Sensitive Fuel Pressure Regulator
> Stainless Steel braided -10 fuel feed lines
> Stainless Steel braided -6 return lines
> Custom modified fuel rail
> 95# injectors acceleronics Impeadance converter
> NX wet kit 100 shot
> Alky Control Dual Nozzle alky kit pure Meth
> car weight 3357#s with me in it 3567#
> Rossler custom bad *** TH 400
> Protorque 10.5 converter
> 9inch rear detroit locker 3.50 gears
> Spohn Drag Race sway bar and TQ arm
> BMR K member and a-arms
> Hal Qa1s
> wolfe travel limiters
> Metco LCAs
> 693RWHP 713RWTQ Blower only
> 811RWHP with 100 shot
>>>using a stock OBD1 PCM with CAM tuning!
> best ET 9.12
> best 60 1.26
> best MPH 150.88
> Better times to come Soon!
Either will do Nicely
Make sure, if you have not already, to Call MADMAN and get a set of "Save-Your -*** Bars" For the landing
I would prefer not to have to make that decision again. Now that my shakedown run is out of the way I will be going big next time out myself. Keep me posted and again good job!!
Tony
Tony
I could always up the Jet too
Looks like I will hit the track again on september 15th I just need to find a couple people with video cameras to tag along.
