running a 52mm tb?
Old Sep 4, 2007 | 12:31 AM
Formula350's Avatar
Get forced induction. That's where it spawned from, high altitudes and engines starving for air. Mind you, this was in planes, not cars, but us crazy people always find a way to get one thing working for another
Old Sep 4, 2007 | 04:57 AM
Puck's Avatar
Originally Posted by GIZMO
To make me a believer it would have to be back to back runs with as much detail as possible (coolant temp, A/F ratio, etc.). And no cooling fan running in front of the car.
I do not have a my stock TB dynos anymore and I already mentioned they were not same day dynos
I have never seen a dyno not use the front cooling fan, on LT1 or not. Loading the engine without cooling it like it would be naturally doesnt seem like a good idea to me - I sure wouldnt let them do it with my car.
Old Sep 4, 2007 | 07:17 PM
GIZMO's Avatar
When I dyno I pay very close attention to the engine temp and try to do all tests within a few degrees. My fan and electric water pump are on manual switches. The engine cooling system takes care of itself.
Placing a large fan blowing cooler denser air into the intake tract can often lead to misleading dyno results. I try to eliminate every variable that I can. Maybe that's why I don't get those great dyno numbers that I always read on here?
Take Care,
Daren
Old Sep 4, 2007 | 07:54 PM
Puck's Avatar
Take Care,
Daren
I guess it would slightly inflate the numbers. I doubt its why your numbers arent like those impressive ones always posted - I always use the front fan and am still trying to find out why my combo comes up short compared to most posted numbers on forums...yet runs faster times???
Old Sep 4, 2007 | 10:00 PM
Formula350's Avatar
Like I said, I would assume they use that not just for cooling purposes, but for simulation purposes as well. If I was you, I'd run 2 with and 2 with out. Both after the car is up to operating temp.
Old Sep 5, 2007 | 07:27 AM
GIZMO's Avatar
I appreciate the input, but in my opinion a dyno is only good for getting a base tune and for testing parts. The absolute best test station is the drag strip (or where you intend to run the vehicle). After a dyno session I generally data-log some passes and make A/F adjustments. There is no way that you can simulate racing conditions with a fan due to the difference in vehicle speed in real world driving situations. I also log and adjust my tune for changes in DA.
Old Sep 6, 2007 | 09:05 PM
LittleRedZ's Avatar
I think he's pulling out the "Rule of the Internet" card. "Pics, or you're lying". Or in this case, a link with said dyno sheet/results. I'm not sure if ws6.com/org/net (whatever) has a TB dyno.
what are you running with those mods in your sig? i really dont care about dynos cuz i dont race dynos.
but heres some number for ya
cat back exhaust, cat delete,stock exhaust manifolds,2800 stall with stock 2.73 gears, full weight on 17" ss wheels/nittos
12.92@105.9. That was my car and those were my mods just because you drop $400 on a pointless T/B and some injectors dosent mean you going to go fast. I put a 52mm T/B on after those mods and didnt pick up a .5mph or a even .1, as a matter of fact it did absolutly nothing.
Judging by his mods 1.6 roller rockers would be money much better spent
