running a 52mm tb?
So i'm worried by running too big of a throttle body might do something similar to over sized exhaust. Bare in mind i'm not to knowledgeable on throttle bodies. That's why i rather ask before going out and buying one.
Any advice is greatly appreciated.
I remember putting my 58mm on my TPI car and I noticed a ton more throttle response and all I had done was ported the upper plenum. Alls I had for exhaust work was a Flowmaster (might've been a dump at the time) and catless.
Since you're M6, you don't have to worry about a tune either. Once you get the headers though, I'd get a re-tune. Even with the 52mm you could change the VE table a bit.
I have pacesetter LTs and a tune from madz28.com already. Ok so then this would be a good step forward for me thanks.
When you say stocker, do you mean buying a GM 52 or 58mm? Instead of a holley etc...?
And yes, I think it'll help your car breathe better.
What's that "slp flow booster"?
So should i talk to Brett Bauer? I heard he does ported throttle bodies right?
that's just an air foil that goes into the throttle body. I bought SLPs version.
http://www.slponline.com/view_product.asp?P=22100
I don't know how good Brett is. The ones on eBay people seem to be having good luck with and they only run like $100-$140. Some come with Airfoils already as well. Alternatively you can just send yours out to have it done. You might even have a local shop that can do it. Like me, I have TPiS just a few miles away
oh ok man, well thanks for the advice then, i appreciate it. I'll probably check to see if someone is local first.
I know of at least one SS/IA LT1 Firebird that has run as fast as 9.713 with the stock throttle body (N/A).
I have a friend with an LT1 A/FI Stocker that has been 10.147 with the stock throttle body (N/A, stock lift cam!!).
I have had great results too.
Daren
Daren
Even though the examples you posted are true, I do not think those cars mentioned are really a great representative of real world use, since with the low lift/huge duration cams the engines use do not neccesarily need a big TB to breath in more air per intake stroke since they get their air by keeping the intake valve open for much longer then a street driven engine would. Of course its much more complicated then this, but since engines intake air in pulses and not streams, it is basically it is a longer(higher duration) but shallower(lower lift) breath instead of a shorter(less duration) but deep(high lift) breath to get the air it needs. My cam is relatively high lift for its modest 230's duration, so maybe that is why I see a benefit when full second+ faster cars with less lift do not?
Personally, even on a bolt on engine I would get one just because I like the snappy response off the line from a big TB. Of course it will not be used to its full potential cfm wise on a lower RPM/CI engine, but it will not hurt anything(assuming its tuned, i/e funky auto tranny problems due to TPS/road speed variations aside).
Like many other things it comes down to preference
