Lifted or burned a Head gasket......
Originally Posted by TwoFast4Lv
Parts are on the way! heads are going to the Machinest to be checked out in the morning!
I got a feeling that is what the Machinest will be doing He does all our work. If I did not question them I would have bolted them right back on
Thanks!
Did you Re-torque the heads? What TQ and Botls did you use?
Looks like they pushed out alot like mine. I know mine was from a lean hole running on juice. We rejetted teh hole and went some more but the damage was already done.
You know, I may not have gone back and retorqued them. The engine sat assembled for a while before I put it back in the car. I use ARP bolts and I don't remember the torque off had but I would have used the ARP recommendation with their assembly lube.
On the ARP bolts I used the ARP Sealant. You want to use the sealant on the threads so the bolts do not leak
Good news bad news from the machinset. Decks were great...Three cracked intake ports and a broken Vavle Spring
Originally Posted by daniel6718
woah...not on those heads...is he goana fix them or are they goana go back to lloyd?
can you weld them back up?
hope their not trashed...ive never heard of cracked intake ports
No Worries. They are already at the welder. When we bilt them Lloyd set them up to use Stock rockers. Problem is with the Cam I run and the lift it has they still hit the Intake ports so I had to go to offset rockers. The good news is we now have more room to weld
I was more worried about the valve spring that broke. Lost an Inner spring and and beat the hell out of the seal and guide.
More parts to order I am never going to get that MADMAN kit on at this rate LOL!
#32
good to hear...just saw your other thread...thinking about a differant setup huh?
stock heads not good enough...
