Bored TB
Old Sep 5, 2007 | 10:50 PM
PEZ97T/A's Avatar
Default Bored TB
Hey if anyone out there bores TB hit me up i wanna bore my stock one to 52mm Thanx.
Old Sep 6, 2007 | 12:05 AM
Formula350's Avatar
The question is, how much do you want to spend? Because bored stockers are cheap on eBay.
Old Sep 6, 2007 | 01:19 AM
ZONES89RS's Avatar
In-Zane Moderator
^^^^X2
Old Sep 6, 2007 | 01:03 PM
PEZ97T/A's Avatar
Well should i buy a stocker or an aftermarket?
Old Sep 6, 2007 | 09:08 PM
Formula350's Avatar
For 52mm, buy a ported stocker. For 58 you have no other choice than aftermarket.
Old Sep 6, 2007 | 10:53 PM
PEZ97T/A's Avatar
What changes would i have to make tunnig wise from 52 to 58?
Old Sep 6, 2007 | 11:30 PM
koolaid_kid's Avatar
The first thing you would have to do is bore the manifold, since stock is 52mm. If your sig contains all your mods, I am not sure why you would have to retune.
Old Sep 7, 2007 | 06:19 AM
Formula350's Avatar
Even going to 52, assuming you're an A4 car, you'll need to change the tunning to accommodate the extra airflow in conjunction with the line pressure. Since that's being done, you might as well have the car tuned anyways
Old Sep 7, 2007 | 04:05 PM
PEZ97T/A's Avatar
Thats true aight cool thanks but it does already have a madZ28 tune and stuff.
Old Sep 7, 2007 | 08:39 PM
Formula350's Avatar
Doesn't matter. He'll have to re-tune it.
Old Sep 7, 2007 | 10:21 PM
PEZ97T/A's Avatar
O aight coo thanx for the help.
Old Sep 7, 2007 | 10:39 PM
PEZ97T/A's Avatar
Aight Cool thanx.
Old Sep 7, 2007 | 10:45 PM
SS1156's Avatar
Stock is 48mm. You will have to open up the intake to accept the 58mm tb.
Old Sep 7, 2007 | 11:01 PM
nighthawk15's Avatar
EDIT: sorry, misread the post above me.
A 52mm will bolt right up with no alterations needed because though the stock tb is 48mm, the openings on the manifold are 52mm. For a 58 you wil need to port the intake.
Old Sep 8, 2007 | 10:04 PM
PEZ97T/A's Avatar
o ok coo so 52 bolt on sweet so what are the better ones out there like i kno holley is good and bbk but which would yall recomend.
