spark + fuel, still DOES NOT start. HELP
Old Sep 6, 2007 | 08:54 PM
lt1 power's Avatar
Default spark + fuel, still DOES NOT start. HELP
what could cause the car to not start, car just cranks over and will not start for the life of it. what could be causing this problem. anybody
Old Sep 6, 2007 | 11:56 PM
Formula_LT1's Avatar
Well, you description is kinda vague, so I can't really pin point one particular thing, but there are a # of things that keep a car from stating.
-Bad/weak Fuel pump
-bad distributer/igniton module
-depending on the year the crank sensor
-bad coil, or coil wire burned or severed
Really could be anything.
Old Sep 7, 2007 | 11:42 AM
lt1 power's Avatar
i'm thinking the fuel pump is starting to die on me, what the normal fuel pressures, with key on, started, etc? thanks
Old Sep 7, 2007 | 01:37 PM
ThoR294's Avatar
fuel pressure should be around 40PSI
