Front shock replacement
Old Sep 7, 2007 | 04:20 PM
crz28's Avatar
Default Front shock replacement
Is changing the front shocks on an lt1 camaro very difficult
Old Sep 7, 2007 | 04:55 PM
infinitebird's Avatar
It's not that hard, you need to rent/buy a spring compressor, but that's the only special tool needed.
Old Sep 7, 2007 | 05:13 PM
ThoR294's Avatar
+1 its very easy
Old Sep 7, 2007 | 05:19 PM
ROCNDAV's Avatar
Not really. you'll need spring compressors (can buy /rent from Autozone) and some shocks (usually older ones) will need lots of WD40 sprayed on the top nut.
Two bolts on the botton and 4 up top. Take out the assembly then compress the spring.
Old Sep 8, 2007 | 09:09 AM
crz28's Avatar
thanks
