CSR electric water pump install?
Old Sep 8, 2007 | 06:27 PM
Hark_Z's Avatar
Default CSR electric water pump install?
Any good write-ups? I suprisingly couldnt find anything that hit the nail on the head here. I have the mechanical pump off the car already, and the new EWP has already been modified to fit in the housing. I just dont know what to do with the freeze plug and the two electric wires coming out of the electric impeller??
What de Hell?
Thanks for any help cant wait to get the damn car back together.
Old Sep 8, 2007 | 06:32 PM
SincalT/A's Avatar
freeze plug goes in back of the waterpump housing where the impeller was.the to wires are blue + and black - you need to set the + off a relay wired to your ignition.
Old Sep 8, 2007 | 06:38 PM
Speed Density's Avatar
hashtagBMW
1 1/8 freeze plug, put it in from the front.
Blue - Positive
Black - Negative
Run the black to the radiator support ground right next to the CAI and run your power to the air pump fuse in the underhood fuse box. Or to another switched source.
For reference:
Pink
- 12v Switched
Red -12v Constant
Old Sep 8, 2007 | 06:52 PM
SincalT/A's Avatar
oh ya! take the coupler off the timing chain i see it is still on in the picture.btw i also used my air pump ignition hot side i just didnt know if you still had your air pump in use.
Old Sep 8, 2007 | 07:27 PM
SincalT/A's Avatar
also check the 4 allen bolts in the front of the water pump motor. they have been known to back off and ruin the bearings inside.mabe locktite them before the install.
