Starting prob
Old Sep 9, 2007 | 03:09 AM
FormulaZ's Avatar
Default Starting prob
Tried to start car and all I hear is the clicking sound. Just changed out my fuel pump and when I try to start I could hear it prime and interior lights and gauges work. I tried to jump it so I could check the alternator but it still wouldnt start. Any ideas?
Old Sep 9, 2007 | 03:16 AM
Formula350's Avatar
Starter is toast.
Old Sep 9, 2007 | 12:36 PM
FormulaZ's Avatar
Well changed out the battery and it started right now. Tested the alternator and it was working as well. Now just gotta deal with a rough idle.
Old Sep 9, 2007 | 03:32 PM
Formula350's Avatar
Well, a correct jump would've done the same as if you dropped in a new battery. Or even better, since you can draw more from the other vehicle. Very well could've been the bat, but I still think the starter is the culprit. If it happens again and you have a dead battery, you'll know.
Old Sep 10, 2007 | 04:17 PM
2nd3rd4thgen's Avatar
if it happens again try checking the battery terminals if they are bad it can cause that to happen.
