Header Q's Need oppinons!
Old Sep 10, 2007 | 10:54 PM
infinitebird's Avatar
Originally Posted by Pntbll309
A small LE1 cam head job soon or a later.This is the kit:
http://www.rksport.com/shop/item.asp?itemid=381
If you're doing h/c later you absolutely want LTs.
Old Sep 10, 2007 | 10:59 PM
Pntbll309's Avatar
Even If its a small h/c job?
Old Sep 10, 2007 | 11:05 PM
Even a small h/c is going to be moving more air than stock. Free flowing exhaust/intake are important supporting mods for that. Go to lloyd's site and read the description for the LE1. His advertised #s are only with LTs. Go with anything else and you will make less. If emissions are not an issue, just do it right and get the good stuff.
Old Sep 10, 2007 | 11:08 PM
Pntbll309's Avatar
Well exhaust wise itll be the mids, ory and cutout...Emissions dont affect me. I see people with mac mids running h/c...Whats up with that?
Old Sep 10, 2007 | 11:11 PM
Well the cutout would definitely help.
And you shouldn't judge a good setup just by what other people are running. Plenty of people run a flowmaster exhaust, doesn't mean its optimal for getting the most power.
Old Sep 10, 2007 | 11:36 PM
transamws6_97's Avatar
yeah don't get mids if you plan on doing a h/c swap. thats just stupid. its one thing to put mids on a bolt-on/stock motor but putting mids on a h/c motor would be like keeping the manifolds on the stock motor, your just gonna choke the **** out of it
Old Sep 10, 2007 | 11:47 PM
Pntbll309's Avatar
Oh I understand that (saw everyone with flowmaster and decided "hey they must be good" Then I found ls1tech.) But my mind just wonders how these other people are doing it. The cutout will be mounted RIGHT after the Y before the cat. I debate every day, if I should put money into it or sell it. But I know 100% that it will be geared and stalled for sure. H/cs down the road a little. But not too far.
Old Sep 10, 2007 | 11:51 PM
you said you didnt have emissions to worry about then why are you putting a cat on your car? thats just as bad as putting mids on if not worse
Old Sep 10, 2007 | 11:58 PM
Pntbll309's Avatar
No muffler shop will weld in a straight pipe. I cant weld so Im phucked. I would more than happy get rid of it. But nobody will weld the cutout inplace of it.
Old Sep 11, 2007 | 12:42 AM
FiredUpZ28's Avatar
Just get an off road y pipe. Or at least make sure its a high flow cat. Even still, if theres no emissions, just get an ORY. Cheaper than a catted Y.
Old Sep 11, 2007 | 12:56 AM
Pntbll309's Avatar
It will be an ORY and my Cats a Magnaflow hi-flow.
Old Sep 11, 2007 | 01:09 AM
  #32
well find a buddy that can weld or a performance shop. most speed shops will get rid of your cat.
Old Sep 11, 2007 | 02:24 AM
  #33
Irish350's Avatar
go coated LTs... idk if id trust them used (since pacesetters are known to need some 'modification'), but either way, get them bitches smeared with some ceramic coating... it isnt for looks, its for heat retention.
btw, you can get coated pacesetters NEW for under 400 bucks... well worth it.
Old Sep 11, 2007 | 03:43 AM
  #34
ATAY383's Avatar
id go with kooks headers they are really good just remember what u spend is what u get.
Old Sep 11, 2007 | 05:58 AM
  #35
fbodyracing1's Avatar
i love my pacesetter lt but if i was to do it agian i would buy new Prothane motor mount and do it will im doing the header it not that bad to put them on with the header on the car it just drove me nouts when my header keep hitting the floor
