longtubes
Old Sep 10, 2007 | 03:46 PM
camaro-94-z28's Avatar
Default longtubes
i want to get a set of pacesetter long tubes and i got flowmaster cat back ( i know i know chock master but thats what was on the car when i got it) and brand new y pipes. well they just bolt right up? or is there some kind of welding needed to be done. how much ground clearance will i have?(2inch drop). where can i get them cheap? ... im also thinking about long tubes and strait pipes (LOUD ) but i only got 500 is that do able to just bolt right up? if so where can i get the pipes? thanks!
Old Sep 10, 2007 | 04:25 PM
infinitebird's Avatar
No welding needed (unless you want to weld on flanges), but you will get better seal if you use band clamps instead of the included clamps. Many of the sponsors have the pacesetter headers. --------->
Old Sep 10, 2007 | 04:33 PM
Pntbll309's Avatar
For $500 for both...No.
Old Sep 10, 2007 | 06:31 PM
nomoneyz's Avatar
If you get uncoated ones and an ory that should be almost $400. Then $100 left aint gonna get you much.
