MSD PRo Billet Opti-->timing question
edit: dyno tune would be the way I'd go.
See if you can find the directions that came with it, or download them off of their site. If you can get a good view of the screw, the directions will tell you how many threads should be exposed for stock timing, and then you can go from there. At least thats what I seem to remember reading....
Directions
The timing adjustment is even at the top of the directions.
Damn man your always so negative..... Maybe the few people who have had issues had a hungover ******* assemble their distributer that day or something.
To the OP, I hope my link to the directions helps.
I am not negative, I am objective and intelligent, I know that clashes with what is found here most of the time. Try getting a grip on reality rather than blindly believing anything expensive is great and perfect.
I was just saying the only way to know is to check it, without measuring it you are guessing, guessing worked fine on older carbed stuff but with the pcm constantly trying to adjust things you aren't going to be able to tune a computer controlled car by ear.
I also have a piece of **** 2400rpm Stall B&M TC that I believe could be bad. The tranny that I replace in my car had this and it may have gotten a little low on fluid since the tranny slipped. But I was never really sure since my last opti was so bad I am not sure how it even started let alone drove the car! I took my friends advice about going with the B&M TC instead of just throwing the stock one back in it, maybe they are right. But this car used to run faster bone stock and that took a nose dirve when the opti started acting up bad. I have thrown $1400 at the car and it runs a few tenths of a second faster than it did before, but not even close to what it was stock. Its just frustrating as hell... But the saying applies here, "If it has **** or a motor in will give you ****!"
Thanks for the help guys! anymore ideas you have I would certainly be glad to hear them!
