Pretty happy with track results!
Old Sep 13, 2007 | 01:58 PM
-PEPE-'s Avatar
congrats
Old Sep 13, 2007 | 02:11 PM
LT14LIFE JT's Avatar
What elevation are you running at? Also, what was the DA the day you ran? The stock bottom end record is 10.80, so there's alot left in your H/C LT1 to be seen. I've ran your times in a bolt on, full weight LT1, so I'm sure there's at least another .5 left in that car with just tuning and traction. Good luck and hope you reach your goal.
Old Sep 13, 2007 | 05:03 PM
grn95t/a's Avatar
i see u have 4.10's, two ? what size rear tires and what rpm's at the end of the run?
Old Sep 13, 2007 | 06:07 PM
Ls1Bait's Avatar
Dont know what the elevation or DA was. I have my stock salad shooters on and nittos on the rear. I have a yank 3600 converter and I did dead hook out off the line. I ran 13.2 with only headers,stall and 4:10 gears, And I have only had the heads lightly ported and the cam and I am .8 tenths faster. I figured it was pretty good, considering I still have more tunning to do. I was crossing the finish line at like 5800 rpm which is what my shift points are set at. I logged the run if anyone would be interested in seeing it? I am pretty happy about the run and What I have done, The car also weighs 3500 pounds.
Old Sep 15, 2007 | 07:47 AM
Oh yeah, you definately have a strong running LT1. The sky's the limit now that you have a baseline for the mods done. You will be deep in the 11s before you know it.
Old Sep 17, 2007 | 02:03 PM
96mikez28's Avatar
Not Bad!!
