Pretty happy with track results!
Old Sep 11, 2007 | 11:16 PM
Ls1Bait's Avatar
Default Pretty happy with track results!
Went tonight to route 66 and was expecting to go slower, I think with some fine tuning(I tune the car myself)I could get it to 12 flat! I only have my shift point set at 5800 (I did it for break in on the new motor and to learn how to set up my shift points) so I think I can let them out to 6500. When the car went on the dyno right after the new motor I built, It was still pulling power all the way up to 6200 rpm so it must pull to 6500 easily. The only thing I wasnt happy about was the MPH, but with some tunning it should go up. Unfortunatly the season is comming to an end but I will be at the track in a couple of weeks and again in a couple more. Well hears the time slip, I was 22 and left side.
Old Sep 11, 2007 | 11:27 PM
Gun5's Avatar
nice love to see Lt1's doin it big keep the LS1's guessn
Old Sep 11, 2007 | 11:29 PM
hammrman31's Avatar
great 60. car must launch well. great et too.!
Old Sep 11, 2007 | 11:32 PM
LS1 Eddie's Avatar
Looks really good. The converter and tires sure help though. Wish we knew more about the setup!
Old Sep 11, 2007 | 11:47 PM
1989GTA's Avatar
Not bad at all. Looks like you were snoozing at the light.
Old Sep 11, 2007 | 11:53 PM
97bagds10's Avatar
i put a holeshot 2400 stall in mine and it dropped my 60' by .2 sec's(from a 2.25 to 2.05). havent made a complete run due to the tranny not shifting right but before i couldnt pre-load at all. clean car, and yes i agree with the top end MPH. not all that good considering you only gained 20 mph in 1/8 mile.
Old Sep 12, 2007 | 01:29 AM
speed_demon24's Avatar
I cut a 1.86 60' on my stock converter....
Old Sep 12, 2007 | 06:18 PM
Ls1Bait's Avatar
Any Ideas to get my MPH up? I was gonna change my shift points but other than that im not sure what to do. Im getting a wideband next week so I may be running rich up top.
Old Sep 12, 2007 | 06:45 PM
1slowZinthe513's Avatar
nice times!
Old Sep 12, 2007 | 09:52 PM
Whats your heads/cam setup? Hopefully the shiftpoints and tune help out since 106mph is what most bolton cars trap.
Old Sep 12, 2007 | 11:30 PM
Ls1Bait's Avatar
^^^I have a 230/236 565/565 on a 112, comp custom ground cam. I have stock heads/intake port & polished by a local guy that does awesome work at a great price. The same machine shop did my engine, after I had spun a couple rod bearings. They reground my crank, did aline hone on the mains and honed the cylinders. I assembled the motor myself and put it in.
Old Sep 12, 2007 | 11:43 PM
97bagds10's Avatar
wanna cookie?
Old Sep 13, 2007 | 12:09 AM
the_merv's Avatar
I wanna Cookie...
Nice Times bro, that will smoke some LS1's..
Old Sep 13, 2007 | 12:42 AM
TwoFast4Lv's Avatar
Nice runs!
Old Sep 13, 2007 | 01:09 AM
Taubr Unit's Avatar
hells yea, i wanna get my car out and see what it runs. I just got my shift points changed so i should be ready to roll. How strict was 66 on tech?
Old Sep 13, 2007 | 08:06 AM
Javier97Z28's Avatar
Are you running at 6000' elevation?
Old Sep 13, 2007 | 08:56 AM
zigroid's Avatar
you should be trapping ALOT higher. over 110 mph.
Old Sep 13, 2007 | 10:38 AM
dre2013's Avatar
im sure your shiftpoints are holding you back alot...I am looking into getting a comp 230/236 cam for my next lt1 project, how is it as far as driveability? i had a cc503 in my last t/a with p+p heads,LTs,etc...after the engine was broken in i wasnt sure where to shift at, so i was shifting around 5800 as well...after running dead even with my friends LT1 that ran 13.6, i realized i neeeded to shift higher...we raced again with me shifting at about 6200-6300 (going off of factory tach) it was a completely diff race. i guarantee you'll pick up a decent amt of mph with changes in your shiftpoints...i would wait until you are comfortable enoguh with it being broken in first though.
James
Old Sep 13, 2007 | 01:34 PM
wanna cookie?
My point was not to go cheap on the converter since people cut better 60's with a stock converter than youre "holeshot" converter.
Old Sep 13, 2007 | 01:48 PM
werd, those b&m holeshots make better doorstops.
