what oil filter are you using
I use the AC Delco Ultraguard Gold PF52 in my car. When I don't have in stock I use Pureone Filters.
Fram sucks BTW
FRAM, has some kind of jell after the blow back valve, paper ends and not much filter element, little piece of metal at the bottom holding it together (acting as a spring)
Delco, has metal ends and decent filter, little piece of metal at the bottom holding it together (acting as a spring)
Wix, metals ends, Has filters inside the filter, has a real spring in it
also found out some other cool stuff wix is the biggest filter maker in the world, also its the filter most used by auto manu's from the fact even though they might not say wix
NAPA Gold = wix
we also rated motor oils, sorry guys that run royal purple and all that syn ****, castrol GTX takes the top next to (ill have to look)
AVOID FRAM LIKE THE PLAGUE.
This is the page to study:
http://minimopar.knizefamily.net/oilfilters.html
