My Plug Gap?
Old Sep 13, 2007 | 02:51 PM
Gun5's Avatar
Default My Plug Gap?
Well Iv seen with around 400 hp and MSD ignition 35-40? was leaning towards 35..
these are NGK TR55
Old Sep 13, 2007 | 06:51 PM
Puck's Avatar
My very qualified tuner prefers and recommends between .030 to .035 for plug gaps. I had mine at .035 and now he wants me to go down to .030 on my next set.
Old Sep 13, 2007 | 11:23 PM
Gun5's Avatar
ya I was thinking .35 for now and next set .30 and if i notice a bad/good diff go back or not
Old Sep 22, 2007 | 08:20 PM
Gun5's Avatar
whats ur ignition
i got a 6AL, MSD wires, MSD Coil and MSD Pro Opti so i know im juicin it alittle more then stock
Old Sep 22, 2007 | 08:25 PM
Puck's Avatar
Originally Posted by Gun5
whats ur ignition
OEM opti unit with MSD cap and rotor, MSD "Blaster" coil, and Taylor Thundervolt wires w/ tr55 plugs.
Old Sep 22, 2007 | 08:44 PM
Gun5's Avatar
from what I hear any kind of after market box raises the gap about .5 because they juice it that much more like i said i was leaning toward .35 maybe
Old Sep 22, 2007 | 09:03 PM
Formula350's Avatar
Stock coil puts out more in the higher Rs than the MSD ones
Old Sep 22, 2007 | 09:09 PM
procharged355's Avatar
yea I would do .035 unless you are forced induction or nitrous
Old Sep 22, 2007 | 09:22 PM
Formula350's Avatar
This dude says .050 unless you're running FI or NOS. Then you go .035
https://ls1tech.com/forums/showpost....21&postcount=1
Old Sep 23, 2007 | 12:59 AM
Gun5's Avatar
hmm i sent him a msg
Old Sep 23, 2007 | 07:34 AM
wrd1972's Avatar
Mine are set at .050" and I dont have N2O.
What is the reason you guys are going to .035" when OE spec is .050"?
Old Sep 23, 2007 | 08:38 AM
Puck's Avatar
...yea, and then higher compression and rpms is supposed to make the cap go down again. Those rules are way back from standard SBC days, and the LT1 behaves a bit different.
The OEM specs arent always geared towards max power - hence the very modest timing and running pig rich from the factory. In most N/A high performance LT1s, especially in the higher rpms, you get more power and smoother response from a smaller gap in the .030-.035 range. The bigger stock gap tends to "wash out" under high compression and high rpms.
Then again, what credentials does my tuner have - besides being a personal friend of Ed Wright and working as a Chevrolet engineer since before most of us were born, and tuning hundreds and hundreds of TPIs and LT1s in the process .
I gained 35 to the wheels over a professional mail order tune with him.
