FASTFATBOY Idle Video!
edit nvm just saw ur sig.
THANKS!
David
chris
Cam:
254/254@.050, .672/.648` lift, installed on a 106 ICL, LSA 108
She a healthy cam.
As far as the track goes, I am scheduled to be tuned on the 21st of this month. If it survives that thrashing I have to pull the converter out. It is way too loose(will stall 3500 on the foot brake !) get it tightened up about 500 rpm.then wait for cooler air. I will probably go to the track sometime in Nov.
Click the links in my sig for engine pic
David
How do you like that Super Vic setup, anyway?
Will will let you know when it comes off the dyno on the 21st, I can tell you this though, I can be rolling 10-15 mph and floor it and it will leave about 50 feet of 325/50 on the ground untuned and with a converter that is too loose!!
David
cam sounds awesome. might do something similar for my drag car. thats the plan anyways. we'll see.
also I forget, is yours a 396?
and lastly, if its only to be tightened a little, mioght not make a difference. but that could have an effect on the tune. it'll effect how the throttle response is, and the timing I think. ofcourse, Im sure ed wright would tell you that if its true. I know he knows his LT1's.
chris
