rhino ramps
My Dad has a set of ramps that were formed from a wide *** tree. They are heavy as hell but wider than anything you can grab at autozone, good luck on those sliding on you. I like it when I'm up at his house and have use of them.
I had a set of Rhino ramps, the damn rubber falls out of them easy. I have a set of metal ones, my tires barely fit in them..... I gotta find me a strong tree and make me a set of wood ones.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Do not use the cheapest shortest set of jackstands you can find. I have a couple sets of the 6 ton stands from harbor freight and they are great. They start out at the bottom about where my old 3 ton stands would top out. 10 times more stable then the old ones especially if you really have the car up in the air.
For my rear tires if I am working on the car I have a set of wooded stands I built out of 2x4 that are plenty wide even for my 275 40 17 tires. I cut a piece of 2 x 4 at a 45 for each end so that the car would have to actually roll up almost 2 inches to come off the stands and they almost cradle the front and back of the tire so it cant really mover forward and back at all evern before it gets to the stops. They are not very heavy but the way I made them they are strong as hell. These stands are about a foot high so you can really get the car up in the air when working under it.
For the front I have a set of steel ramps that I use but due to the tires being so wide I cut a piece of 2 x 10 so that it sits down where the tires would sit on a normal car. They are cut at an angle so the bottom fits but the top flares out and is almost just as wide as the tires are. I have a smaller lip on these to keep the car from rolling off them as well.
I use 2 jacks to get the car up on these two setups and that is the only part that worries my. If I dont lift onr end at a time up a few inches and block it before going to the other end (front and rear) the car can tilt side to side. Takes me forever to get the car up in the air but once its there its there for good.
If I ever figure out how to upload pics onto here and get a little free time I will take pics of what I am talking about. I think they are great and maybe the can help some of you guys out in the future. I dont need to hear any more bad stories about cars falling.
i terrified of being crushed, rather use someones lift, or let the car be broken. slightly error could casue that 3300 lb car that normally sits 6 inches off the ground (1 inch with out wheels) to fall on my head. rather not. haha
Came close to being killed myself from insufficient methods. The clearance is not as good, but I will drive the car up on ramps and then jack under the diff on the rear and put jackstands under the axle but leave pressure on the jack.
Originally Posted by 96capricemgr
The Rhino ramps have rubber pads built in so they are far less prone to sliding. They are WIDE and fully supported underneath not like stamped steel ones. They are more stable than jackstands long as they are used properly.
I had a set of Rhino ramps, the damn rubber falls out of them easy. I have a set of metal ones, my tires barely fit in them..... I gotta find me a strong tree and make me a set of wood ones.![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
http://www.mustangworld.com/ourpics/...amps/index.htm
