Rebuild?
Old Sep 16, 2007 | 11:20 AM
94Aquaformula's Avatar
Default Rebuild?
Well last night i was drivng on the Highway and Cruising with a couple of Friends and My car started to make a "loud" knocking noise. So i pulled over and called somebody to tow me home. When i got home i jacked up the car so i could hear where the knocking was coming from. I'm thinking its from the bottom of the motor around the crank pully. Just wondering if it could be the pulleys, they are aftermarket and might be off balence. Just haven't checked if they are. Also how much would be a Rebuild for these LT1's i just want it to go back to stock. Just wondering what you guys think it could be. Thanks Calvin.
Old Sep 16, 2007 | 11:32 AM
MEAN LT1's Avatar
Its kinda hard to diagnose something like that without actually hearing it. Does the sounds move as you rev the motor. More than likely its time for a rebuild.
Old Sep 16, 2007 | 11:37 AM
yeah it does when get louder as you rev it.
Old Sep 18, 2007 | 10:05 AM
H82GOSLW's Avatar
Now that it's cooled down, when you start it up cold, did the knocking noise go away? Then does it come back after it warms up? Spun main bearing if that is the case. As far as a rebuild...start with another motor. Your oil pressure at start up will be fine...until it warms up again. This one is junk if it is a spun main bearing. I've already got $2K into my motor rebuild but that's with all high perf. valvetrain parts and replacing all gaskets/seals (amount includes the purchase of a used motor with 40K miles on it.)
Old Sep 18, 2007 | 10:38 AM
k i will. I drained the oil last night and if you looked hard enough you could see some metal flakes. I don't know what that means but can't be good.
Old Sep 18, 2007 | 12:29 PM
thebufenator's Avatar
I had a knocking coming from the timing cover, and it was the timing chain chewing gears up and ripping itself off of the cam.........
STOP RUNNING THE ENGINE
take it apart and fix it before it gets worse
Old Sep 18, 2007 | 12:56 PM
k, the first thing i will do is check the Timing chain. Then go from there. Thanks guys for all the help.
Old Sep 19, 2007 | 12:51 PM
If it is the timing chain, Then how do i put it on and ajust the timing? Thanks Calvin
