How to replace the trans mount
Old Sep 16, 2007 | 07:01 PM
mhayes2344's Avatar
Default How to replace the trans mount
I need some help figuring out the easiest way to replace the trans mount on my 96 trans am A4. Under any more than 1/4 throttle the driveshaft smacks the bottom of the car under acceleration. From what I've read its probably a broken/worn trans mount.
Does anyone know of a step by step diagram of how to do this? Also does it make sense for it to be the trans mount?
Thanks in advance
Old Sep 16, 2007 | 07:07 PM
XX11SECZXX's Avatar
yea it is common to break on those cars. its pretty simple jack the trans up unbolt the mount and replace it. im not sure on the 4th gens but you might have to pull the crossmember and if thats the case its only 4 bolts. i would recommend an energy suspension for i havent broke mine yet.
Old Sep 16, 2007 | 07:55 PM
James Montigny's Avatar
Pretty straitforward
Support tranny, remove crossmember, replace mount, reinstall crossmember.
I've broken a few
Old Sep 16, 2007 | 07:58 PM
http://images.google.com/imgres?imgu...3Doff%26sa%3DN
LT1 process is almost 100% the same.
Old Sep 16, 2007 | 09:26 PM
mhayes2344's Avatar
thanks...I figured it wouldnt be too hard, but I like to know exactly what Im getting myself into before I start a project.
Old Sep 16, 2007 | 09:36 PM
TXFORMULA's Avatar
that is very wise,grasshopper...
i have gone to make a few mods without knowing what im getting into. its not pretty...good looking out
Old Sep 16, 2007 | 10:06 PM
95CamZ's Avatar
I've broken a few
Thats exactly how you do it!! I broke mine 2 months ago along with the motor mount!!!
Old Sep 16, 2007 | 10:22 PM
Formula350's Avatar
Get an Energy Suspension Poly one. You'll never go through another tranny mount again.
Old Sep 16, 2007 | 10:23 PM
mhayes2344's Avatar
As have I. Not on this car, and I want to keep it that way...it sucks being stuck in the middle of something because you dont know exactly what you're doing. I just ordered the energy suspension trans mount so hopefully it'll be going on the car this weekend! Hopefully this fixes the problem cuz I'm tired of seeing the car sit...
Old Sep 16, 2007 | 11:59 PM
Pntbll309's Avatar
It took about 10 minutes to do. Its not too bad.
Old Sep 17, 2007 | 12:07 AM
1slowZinthe513's Avatar
yea 10-15 min.. when I had the A4 I went through 4 of them
Old Sep 17, 2007 | 12:25 AM
Gun5's Avatar
ya with the m6 conversion im doing a poly the first time, i figure these cars with the M6 would tear'm up more since well you can get really rough with a M6.. not saying a built auto cant tear it up
Old Sep 17, 2007 | 01:08 AM
Pntbll309's Avatar
Im on my second. I was in a hurry and couldnt get a prothane one so Im waiting for this one to go to ****.
