High Flow cats?
Old Sep 18, 2007 | 02:10 AM
MikegotaZ28's Avatar
Default High Flow cats?
Do they actually add any performance? Anyways, real question though is i have a 95 1 cat, if I throw on a generic high flow (it's free) will it throw codes?
Old Sep 18, 2007 | 04:05 AM
Mercerius's Avatar
I also have a 95. Last year it failed emissions... dead cat. There are times I really hate living in CA. Anyway I tried a Magnaflow high flow cat (OBD1 compatible, but used regularly for OBD2) and it passed easily. No codes and no particular gains (that you might feel) either.
Old Sep 18, 2007 | 04:12 AM
Ralls's Avatar
High flow cats are usually more compact and have larger inlet and outlets. The only time you will gain from one, is when exhaust system is bottle-necked with a small cat and large tubing. No codes either.
Old Sep 19, 2007 | 12:37 AM
Iwantamaro's Avatar
if i got a high flow cat with a magna catback would it be louder?
Old Sep 19, 2007 | 08:09 AM
95ZRagtop6M's Avatar
I have two 3" metal substrate cats on mine. A typical ceramic substrate cats has 400 cells per inch, mine have 300 cells per inch. They cost a twice as much as ceramic though.
