2 questions about recently installed gears
Old Sep 18, 2007 | 12:18 PM
cruzin94's Avatar
Default 2 questions about recently installed gears
1st do gears need a "break in" period of any kind and how long and what should i do to break them in and should i change fluid in the near future.....2nd im pretty sure it threw my speedo Way off cause i no gears help but i can do 100 in no time so do i need it to get recalibrated.....i went with 3.73's and i had 2.73's in a A4 ......and any thing else i should no about them
Old Sep 18, 2007 | 12:29 PM
Formula96's Avatar
200 miles, change fluid, have fun. Dont know about the 94 speedo, mine has to be reprogramed but yours is obd1, might just have a speedo gear that needs to be changed?
Old Sep 18, 2007 | 01:55 PM
burnzilla's Avatar
Just drive the car nice for a little while.
Its ok to get on it once the car is in motion and the gears are locked in, but any shock from slamming at like a stop, the gas or kickin it sideways you want to keep to a minimum...
The longer and better you break them in will help determine how long they last and sound.
And btw,
I am thinking about doing the same thing, 2.73--> 3.73's.
How do they feel?
If you get your fluid changed when you put the new gears in, Im pretty sure you don't need to do it again.
Old Sep 18, 2007 | 05:52 PM
Nads06111's Avatar
yeah. you DO NOT need to change the fluid. after about 3000 miles i called the shop that put my gears in and they said that it was Unnecessary.
Old Sep 18, 2007 | 06:05 PM
letsrun97z's Avatar
yep no need to change fluid and try to avoid going up steep hills- it will cause more load on them and you dont want that
Old Sep 18, 2007 | 08:43 PM
cruzin94's Avatar
And btw,
How do they feel?
the gears helped out quite a bit it felt like ti really helped 2nd out since u no around 40mph it falls on its face becasue it dosnet shift down...and i liked them but i also had an opti failin so it wasnt runnin great ....and in D at about ?70? (speedo way off) its around 3 grand it dosent shift to 4th it just stays in 3rd but there a good invesment
Old Sep 19, 2007 | 08:36 AM
Formula96's Avatar
Well its all about preferance, me personally, i did not change my fluid and did not do a break in period, but i did not want to tell him that and he goes out and ***** some **** up.
You are right, you dont need to, but if you were changeing the fluid to not only get new fluid in but to also check for metal shavings, it is not a bad idea....
You also dont have to change the engine oil every 3000 miles in some new cars, but people do....
Old Sep 19, 2007 | 08:45 AM
blackz6sp's Avatar
You definetly need to get it recalibrated, your speedo is off, and your shift points are off. Try Brian at PCM for Less
