now what the hell
Old Sep 18, 2007 | 01:23 PM
cruzin94's Avatar
Default now what the hell
i just got gears installed last night and i drove home was fine i took it out to get motor oil so i could change it and it started acting like **** stubbling on its face back firing no power what so ever then i would floor it and it would climb real fast and aroun 4 grand it would get some power and ill be just sittin there and it will back fire i dont no whats wrong i just put plugs and wires in it ....unless i burned another one up i dont know whats goin on ....any help much appreciated
just my luck new 3.73's and somthing else gose wrong
Old Sep 18, 2007 | 01:38 PM
rogez's Avatar
Seems to me like an opti or misfiring problem. Severe btw. Check that the wires are connected correctly because it may be firing the wrong piston at a time.
Old Sep 18, 2007 | 01:55 PM
LT1MAN's Avatar
might have a wire on a header
Old Sep 18, 2007 | 02:02 PM
projekt70chevelle's Avatar
Deff sounds like a misfire, do you have insulator boots on your wires. I know i burnt up a couple with my pacesetters. Also may be an opti problem, you may have knocked the connector out so check the wire that plugs into the top of it.
(P.S. I have an brand new AC Delco https://ls1tech.com/forums/showthrea...ight=optispark , if you find out thats the problem pm me)
Old Sep 18, 2007 | 08:54 PM
cruzin94's Avatar
well i am a perfect example for a failin opti i have all the signs so im bankin its that now i have a dilema should i go with acdelco opti or msd opti and im plannin of doin a water pump so the one i have now dosent ruin my new opti and i was thinkin since everything is already out of the way is it time for a cam??? but i dont no what cam to run so any help would be appreciated with any of my problems
Old Sep 19, 2007 | 01:52 PM
crAzy95Z28's Avatar
MSD opti for sure.
Old Sep 19, 2007 | 01:59 PM
95camaroz28's Avatar
fuel pump or opti
Old Sep 19, 2007 | 06:45 PM
cruzin94's Avatar
has any one ever used the dynotech dynaspark?
Old Sep 19, 2007 | 08:47 PM
crAzy95Z28's Avatar
I actuaslly have the dynaspark.. I honestly forgot the name of it lol...
Ive had it for 4 years now and has been on 2 diff cars. The thing is awsome, but i did spend 6 bills for it when it came out....
So dynaspark gets 2 thumbs from me.
