how to install 150 speedo
Old Sep 19, 2007 | 01:05 AM
That_guy's Avatar
Default how to install 150 speedo
well i got a 150 speedo now. well i need to kno how to put it in. my car comes out the shop saturday
Old Sep 19, 2007 | 09:07 AM
Pntbll309's Avatar
Pull off the trim around the original speedo. Unbolt it,unplug it...Reverse and you got it in.
Old Sep 19, 2007 | 09:15 AM
Hot94Z28's Avatar
I must of missed something. You decided to get your car fixed?
Old Sep 19, 2007 | 09:39 AM
That_guy's Avatar
hahahaha why is everyone saying that yes i did. like i had no choice just doing alil bit of restoration. all i need now is a nose (found it just need to wait till nxt check), passenger sideskirt , and a engine once i get done with that then ill save for a ls1 but for now im working on the lt1.
Old Sep 20, 2007 | 04:00 PM
That_guy's Avatar
ok any other opinions like what tool is need or something
Old Sep 20, 2007 | 04:43 PM
BizZzatch350's Avatar
Moderator
Pull the dash trim off around the cluster, take out the 4, 7mm bolts that hold that cluster in. You'll need an extension on a 1/4 inch ratchet to get to them, hold the steering colum down so you can get at the bottom 2 bolts out. Pull the cluster out, then just reverse.
