V6 to LT1
All in all, I wouldn't do it. There are enough problems dealing with a STOCK LT1 to worry about than also dealing with a swapped LT1/V6. Guys in this forum are finding stock LT1's for around 4-5k, yes, with a lot of miles, but I'd take that over a engine swapped car.
I know that first things first unless you have much love for the car its about pointless to go through with the swap, this much I more than know by now. Anyways I will be brief with my story but I have a 1995 Z28 that I got for $1400 with a messed up body (almost every panel dented, and some rust underneath) and a 1994 V6 that I got for $500 (body in great condition, no rust, etc.). These cars were purchased almost a year apart, so it wasn't my original intent to do this swap, but thats how things have ended up.
Anyways I'm coming down to the final this&that of the swap and I wanted to sort of state some things that I have found with the swap (besides the obvious of dont waste your time) and see if theres something that I am missing.
For me since I had two complete cars I was able to put into the V6 car the z28 cross member, transmission, drive shaft and torque arm, rear end, a couple of brake lines, engine wiring harness, and instrument cluster, also a z28 gas tank and pump. Now, we did have an issue at first of it not sending a signal to the opti spark, we thought the opti was bad (even though it was brand new), but it was some sort of V6 to V8 wiring thing in the body harness side. We also had a similar issue with the VATS (which was turned off in the computer), but the wire coming out of the PCM (the z28 one) needed to be grounded (dont know which specific one) to basically tell everything that it was OK to start the car. Lastly we might be dealing with an issue with the alternator and the car not telling it to charge properly, however the alternator did test bad so I'm getting a new one today.
I'm sorry for some lack of information with a few things, the car is at a local school where my father is an automotive instructor, and his classwork as of lately has been working on my car. It's free labor and storage for me and I know the work will be done right. I guess after all that I'm wondering what I'm missing. I feel like even though the swap is sort of a waste of time and money it is being done right. Basically every Z28 piece I could get has been put in, and every time we hit a wiring roadblock we pull diagrams and compare them, then splice/swap as needed. I suppose that if there is a guide out there I missed I'd love to have a link for it, or else I might take on the task of writing one with some more detail (specifics about the wiring and such).
Thanks, sorry for the lengthy post.
*EDIT*
I did just run across this site: http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm -- The legend at the bottom seems to be pretty handy for what needs to be changed and such. It doesn't get into the specifics of the engine harness to body harness differences between the 94 v6 and 95 z28 though, but that should help some people dedicate to the swap.
I don't know if I agree that the value of the car goes down per-sae just because its a V6. If the vehicle has everything Z28 in it I don't particularly see what the difference is. I would put the value on it somewhere between a V6 and Z28 depending on condition, mods, etc. Certainly doesn't significantly increase the value though.
Mine is finally moving under its own power though, I'm likely going to get the tag for it today and hopefully have it out on the open road in the next couple of days. To re-state the bottom line with this swap though, its NOT worth it unless you have spare time, and get a good deal on two cars (both a Z28 and V6) because trying to source parts individually is gonna suck. To some extent it is "fun" but.. come on... it's just a camaro... an LT1 even... Everyone is right, just save up some extra $ and get an LT1 to start with, or save a bit more an get an LS1. But, if you do get stuck in a situation like I did, or you REALLY want to do it, all is not lost and it is quite possible.
