3/4 inch Header bolts work for install?
Old Sep 19, 2007 | 11:11 PM
Pntbll309's Avatar
Default 3/4 inch Header bolts work for install?
Im installing some mid-length headers this weekend and was wondering if 3/4 inch Bolts would work. thanks
Old Sep 19, 2007 | 11:29 PM
Z28_DAD's Avatar
i think 1" is the norm.
Old Sep 19, 2007 | 11:47 PM
Pntbll309's Avatar
Well, will they work tho?
Old Sep 20, 2007 | 12:56 AM
speed_demon24's Avatar
They will work, but they will have more of a chance of loosening up, and you have more of a chance of stripping out the bolt holes since only they only have ~3/8" of the bolt actually in the threads instead of 5/8".
Old Sep 20, 2007 | 03:00 AM
ZONES89RS's Avatar
In-Zane Moderator
I used the 1 inch bolts, if they were cast iron i would say tare your *** but like said above, might strip threads.
Old Sep 20, 2007 | 10:09 PM
tonskiguy's Avatar
I had 1 inch bolts when I installed my headers, and they bottomed out in the aluminum heads. I ended up cutting like an 1/8th inch from all of them.
Old Sep 21, 2007 | 07:15 AM
Z28_DAD's Avatar
you wouldve been better off using a washer an lock washer
Old Sep 21, 2007 | 06:35 PM
96capricemgr's Avatar
Were they cheap 1/4" flange headers?
Have we met? We live very close, I drove through Geenville minutes ago.
Old Sep 21, 2007 | 08:28 PM
tonskiguy's Avatar
As for the flange, I don't have the measurement handy, but they were FLP headers, Poor design with awful plug access and almost impossible to tighten the bolt by the #5 & 6 cylinder , no way to add another washer, no leaks though . The Heads are TPiS.
As for my local, see PM
