Gas
Old Sep 21, 2007 | 04:40 PM
93blacktransam's Avatar
Default Gas
ok i have a 93 trans am..........when i got it the hole above the gas tank was already cut as if they had messed with the fuek pump.anywho my car keeps dieing at a lil over a quarter some times a lil below......I opened it up when it read 1/4 and died and it had about that much gas in it but wouldnt run......put gas in it and its fine....whats the problem anyone
Old Sep 21, 2007 | 06:55 PM
seawolf06's Avatar
They probably replaced the fuel pump and messed up the bucket assembly somehow.
Old Sep 21, 2007 | 06:57 PM
how do i fix it
Old Sep 22, 2007 | 12:08 PM
dhdenney's Avatar
Fill up more often.
Old Sep 22, 2007 | 12:59 PM
i do all the time
Old Sep 22, 2007 | 02:08 PM
dhdenney's Avatar
I've only seen an Fbody bucket a few times but isn't there a little pickup tube on the pump? Is that missing or turned funny?
Old Sep 22, 2007 | 02:11 PM
dhdenney's Avatar
Here ya go . See looks like the tube is detachable. See if you still have it. When the gas gets below the pump, then it runs out but the tube will extend down further to get the fuel.
Old Sep 24, 2007 | 08:08 PM
it doesnt have that just the filter at the bottom
Old Sep 24, 2007 | 08:22 PM
dhdenney's Avatar
Do you think that's the problem? I've never been in mine. Does the gas come up past the filter sock or is it sitting below that?
