Low voltage when idling
everyone is mistaken in order to increase the speed of the alternator you must decrease the size of the alternator pulley in relation with the crank pulley
thinks of gear ratios
if you have a crank pully that is 5 inches and an alternator pulley of one inch you are overdriving the alternator at a 5:1 ratio
so for every 1000 rpm of crank rotation the alternator spins 5000 rpm
if you go with a larger alternator pulley such as one that is 2.5 inches than you are only overdriving the alternator at a 5:2.5 ratio so for every 1000 rpm of crank rotation you spin the alternator 2500 rpm
so in other words you need a smaller alternator pulley
