Fuel Pump trapdoor 96 fbody vert
i did this on both my 85's and it was a beautiful thing . i know what im doing as far as teh cutting and teh measurements but does anyone have any suggestions as to what i can line the new sheetmetal plate im going to be screwing down afterwards. weatherstripping, aeronautical foam? i want to keep road noise down as well as moisture/fumes/crap etc..
Remove the clutch 5 times
Pulled the motor 2 times
Replace ring and pinion 4 times
Pulled headers and exhaust god knows how many time
All of the above are a piece of cake now so I say to myself what is the big deal with dropping the tank and installing the pump the "correct" way. I can not imagine cutting body metal in the area of fuel lines and altering the uni-body itself.
I am guessing you put the rear of the chassis up on stands, let the rear end drop, remove the PH bar, remove the upper PH bar brace, disconnect some tubes and fittings, remove some heat shields, remove some bolts and finally drop the damn tank. I did this on my jeep Wrangler in 30 minutes tops.
What is the big damn deal with replacing the fuel pump on 4th gen f-bodies?
breaks of course.
Really did not feel like wasting the time it would take to R&I the exhaust, rear end and fuel tank. In my opinion this is the only way to go.
