I Need Help
Old Sep 26, 2007 | 08:32 PM
camaro_rs350's Avatar
Default I Need Help
I have a 95 camaro z28 with a new motor with 7k on it and i recently started getting a misfire. i looked at it and found 2 wires cracked. ok went and got wires. put them on started the car, the same thing. im not sure if its the opti or the cap and rotor. the opti is new from gm so please help me out if anyone can thanks
Old Sep 26, 2007 | 09:50 PM
Ralls's Avatar
check plugs
Old Sep 26, 2007 | 11:28 PM
Formula_LT1's Avatar
Originally Posted by Ralls
check plugs
+1
Old Sep 26, 2007 | 11:35 PM
cool we'll do so not opti then?
Old Sep 26, 2007 | 11:37 PM
Won't swear to it, but its best and easier to check the cheeper things like plugs, criss crossed wires, and things of that nature before pulling off the water pump to replace a $300 item that may not be the cause.
Old Sep 27, 2007 | 12:29 AM
kinglt-1's Avatar
+1 to that.
Old Sep 27, 2007 | 01:01 AM
Thanks Guys I Thank You For Your Thoughts
Old Sep 27, 2007 | 11:13 AM
ThoR294's Avatar
yeah, make sure you have the right wires plugged into the right cylinders
