LT4 Valves
Old Sep 28, 2007 | 12:02 PM
FAD2BLK93's Avatar
Default LT4 Valves
Are the LT4 sodium filled valves worth the money? With the lighter weight I would think that they would perform well. I plan on doing the heads and putting in the hot cam kit but I have heard that the springs still will not be good with the extra weight of regular valves...so since I can get GM parts at cost plus 15% for being an employee thats still 430.00 for the set is the benifit worth the cost? thanks.
Old Sep 28, 2007 | 12:13 PM
Rowdy94's Avatar
I didn't know those were so expensive. They are really supposed to lighten up the valvetrain, but aren't there any other options that do the same or better for cheaper?
Old Sep 28, 2007 | 12:27 PM
FAD2BLK93's Avatar
Intake valves list @30.77 ea my cost 20.17 ea... exhaust valves 46.25 ea my cost 30.31...anyone else selling lighter valves? lt1 valve intake 110 grams...lt4 85 grams lt1 exhaust 95 grams...lt4 75 grams...when you ad the weight savings up thats alot of grams on the valvetrain.
Old Sep 28, 2007 | 02:03 PM
dhdenney's Avatar
Those sodium filled valves are still 1.94", 1.50" or something close to that? Get some titanium valves.
Old Sep 28, 2007 | 03:18 PM
FAD2BLK93's Avatar
They are 2.00 and 1.55...but wouldn't the weight savings help them ramp up quicker?
Old Sep 28, 2007 | 03:43 PM
dhdenney's Avatar
OK I was thinking about stock valve sizes for the LT1. Wouldn't titanium valves be comparable to sodium?
Old Sep 28, 2007 | 04:30 PM
96capricemgr's Avatar
I believe titanium need special seats for street use.
Just get better springs. You want to spend gobs of extra money why not spend money on a good kit instead of the HOT kit.
Old Sep 28, 2007 | 04:58 PM
Ls1Bait's Avatar
why not just buy aftermarket, bigger valves than stock stuff?
Old Sep 28, 2007 | 05:41 PM
People get carried away with wanting bigger. 2.00/1.56 is bigger than stock but smaller than many want to use despite awesome results. Most people like to ignore results though and prefer a good line of BS and a bigger is better mentality.
Old Sep 28, 2007 | 06:06 PM
dhdenney's Avatar
Hadn't heard that but I am using stainless. I was offered titanium valves but chose stainless 2.00"/1.55" instead.
Old Sep 28, 2007 | 09:56 PM
Lonnies Performance's Avatar
LS1TECH Sponsor
Especially if you see the price, most will choose stainless over titanium.
As for LT4 valves.... if you are interested in some, I have a used partial set that I will sell for a very reasonable price. I'll have to check, but I think 2 were missing.
Old Sep 28, 2007 | 10:41 PM
GIZMO's Avatar
If you are dead set on the Hot Cam and you have $430.00 to spend on valves I would suggest that buying undercut 1.94/1.50 SS valves and upgrading the valve springs would be a better option. If you were building a 7000+ rpm motor light weight valves would be the way to go. Either way, don't expect a huge gain from a valve swap.
Good Luck,
Daren
