WHAT DO YOU THINK. HP #'s
Old Sep 28, 2007 | 06:38 PM
powers84's Avatar
Default WHAT DO YOU THINK. HP #'s
i was woundering about my setup. im putting it all on next week.what you do you guys think im going to have it dynoed after so take your guess.
i have heads the guy i bought them from said they flowed 260/190
986 springs, comp cam 306, pace setter long tubes headers, pcm tuned, 4.10 gears, 1.6 RR bowties i think therefrom the hot cam kit. harden pushrods. spec stage 1 clutch and steel spec flywheel. i think thats it oh if you didnt get the clutch thing its a M6. i know they dyno better the A4's.
i think im going to dyno around 350 to 370 hp but i i always hope for more.
Old Sep 28, 2007 | 08:15 PM
96capricemgr's Avatar
You might want to look into the maximum lift capacity of the GMPP rockers since they are a short slot and you are looking to run a lot of lift.
Then again you could just wait and see what breaks.
Old Sep 28, 2007 | 09:34 PM
97blackz28's Avatar
yea the GM rockers max lift is .575 and that cam if I remember right puts you right there or a little over with the 1.6 ratio. May want to think about upgrading.
Old Sep 28, 2007 | 09:48 PM
powers84's Avatar
ok thanks what do you suggest. i was thinking the competions mags from comp cams
Old Sep 28, 2007 | 10:07 PM
Honestly you need to rethink the whole package. The 306 with an M6 is going to get old within a few months. You should go smaller, if you choose well you will not give up performance but you will gain drivability.
That cam is known to surge badly and the M6 does nothing to dampen it.
Old Sep 28, 2007 | 10:15 PM
powers84's Avatar
will i already have the cam. but what do you mean it surge badly. i really only drive it a couple of miles to work and sometimes at the track. this is kinda a starting point for more power im going to put a 383 or i was thinking of a lsx swap i know everyone says just sell and buy a ls platform but thats no fun.
Old Sep 28, 2007 | 10:16 PM
powers84's Avatar
oh what kinda of cam would you suggest just for my future reference
Old Sep 28, 2007 | 10:20 PM
97blackz28's Avatar
the car will buck at low speeds and low rpms. it is no fun to daily drive a car like that, or drive it on the street much at all really.
there is an LPE cam in the 211/219 range and a crane 210/224 or something around those numbers, also the cc503 is a 224/230 and is pretty street friendly or a custom cam is always a good idea.
Old Sep 28, 2007 | 10:31 PM
powers84's Avatar
will thats kinda sucks that i already have the 306 i was going to get the 503 but **** happens i plan on upgrading the engine soon anyways. is this cam going to do better at the track
Old Sep 29, 2007 | 09:14 AM
No it wont do better at the track.
A couple years ago I was impressed with a local 306 cammed stroker f-body running 12.7 on street tires.
My car will run 12.7 on street tires today with more weight and less cam.
The 306 is an OLD grind and was popular with the "bigger is better" crowd, a few guyys have gone fast with it but a lot more guys have gotten sick of the poor drivability.
You have to understand that parts being popular is NOT driven by quality or results but by ignorance and marketing. A lot of guys do not realize their results are mediocre and endup telling everyone how great their parts are and just make excuses when less modified cars go faster.
My car has caused many guys with much more heavily modified cars to make all kinds of excuses and false accusations about how prepared my car is, it is easier to do that than to admit I made better choices than the forum as a whole.
For the forums to be helpful you have to dig through a LOT of BS.
Old Sep 29, 2007 | 10:29 AM
crz28's Avatar
i have that cam in my car and i does get tired , i know you already bought it but i think with the heads youre gonna get and a hotcam you will be close to 360rwhp with a daily driver.
Old Sep 29, 2007 | 10:59 AM
97blackz28's Avatar
not to mention you have to rev that cam higher than most people want to make any power.
Old Sep 29, 2007 | 11:01 AM
High enough to be risky on a stock shortblock.
Old Sep 29, 2007 | 12:07 PM
powers84's Avatar
what cam would be good for torque because thats really what im looking for i dont drive on highways and i go to the track. so what do you guys think im going to just sale the 306 and buy a different one
Old Sep 29, 2007 | 12:59 PM
powers84's Avatar
bump..
Old Sep 29, 2007 | 02:13 PM
Puck's Avatar
If you are looking for low end torque you went WAY overboard. The LPE 211/219 is a great torque cam with very tame street manners assuming your tuner is worth his weight in salt. The crane 227 will give up some of that low end torque but make more up top, sacrificing some drivability for some performance. For the same or a few bucks more though you can get a perfectly tame custom grind that still shines at the track.
In a stock cube LT1 there isnt really any need to go over something similar to the 503 if your car sees more street then strip. Sure, the big cams may dyno higher(if you risk spinning them where they want to be), but you will have to deal with more tuning and drivability problems for little to no E/T gain.
Sometimes people go bigger and run SLOWER times at the track.
Old Sep 29, 2007 | 02:18 PM
kinglt-1's Avatar
306 is good for a 383 isn't it?
Old Sep 29, 2007 | 02:27 PM
Better in a 383 than a 350 but still not anything I would call good.
