to install a cam
Old Oct 1, 2007 | 05:37 PM
powers84's Avatar
Default to install a cam
do i need a cam degreeing tool when i install my cam in my lt1.
Old Oct 1, 2007 | 05:51 PM
FlamingChicken's Avatar
not if you install it dot to dot
Old Oct 1, 2007 | 06:23 PM
powers84's Avatar
what do you mean dot to dot. sorry if i sound dumb but ive done pretty much everything but cam
Old Oct 1, 2007 | 06:47 PM
C5042081's Avatar
the timing and cam sprokets have dots, I believe when #6 is tdc the dots match
http://shbox.com/1/cam_timing_ani.gif
Old Oct 1, 2007 | 10:03 PM
bigdan1's Avatar
degreing the cam is to verify if the cam specs are up to par with the spec sheet .....and also if you want to play (advance or retard ) to play with the torque curve
if you are not use to this, install the gears acordingly and you should be happy
Dan
Old Oct 2, 2007 | 10:47 AM
powers84's Avatar
thanks guys
